Hi guys,
So after a few weeks off I finally got around to pushing to get this done. I started by caulking every gap where the trailer meets the wood. After letting it dry for several days I went after the spar varnish plan. Here it is with two coats. It really made it look nice, I can see why some of you leave them wood! But for me, aluminum is the way to go for the look I want, this step was just one of many "layers" of protection for me to hopefully make this thing last.
I do have a question though about the aluminum:
1. I need the "straight" molding that binds the bottom of the aluminum to the bottom of the walls at the trailer, can anyone tell me what that molding is called? The original camper didn't have a molding there, just the aluminum contact cemented on at the bottom. I have the other moldings for attaching the aluminum at the top corners, I was just going to reuse what was on the camper previously unless there is a reason I should get it new? If so please tell me and I will.
2. Also can anyone show me a close up of how the bottom edge molding, meets the corners where the other molding starts up the sides at the front and back? Just not sure how that is supposed to look, hopefully I explained it right.
3. The way the original camper was built the fenders were screwed into the frame as well as all the way up the fender lip which would mean into the side of the wall. Is there anyway around this? Not sure how I could attach them but don't like the idea of driving 6 or so screws into the side of the wall, but I guess it isn't a big deal to do it like it was originally if that is the best way, I imagine I would just need to caulk the screw holes. I was thinking maybe a way to weld a support on the front an back or something?
Anyway here is pics of todays progress with the spar varnish, next step is to aluminum tape every joint and staple in prep for the aluminum next week:
