coyote wrote:with the a.c. unit in "fridge spot", are you using the Dometic in it's place? dave
absolutsnwbrdr wrote:... When I was messing with the AC in my teardrop, I found that two things were absolutely key: separating fresh air and exhaust, and creating a direct path for the exhaust to exit so heat doesn't have a chance to build up....
coyote wrote:Looks very nice, Mine is the shorter version. I only have room for a cabinet over the "sink" area. It came with and I copied the slider doors. Do you have any issue with your door's sliding open when traveling? Mine do, so we have to be careful of what is left up there. Dave
Return to Canned Hams & Bread Loaves
Users browsing this forum: No registered users and 26 guests
