#2
Re: #2
Postby skyl4rk » Sat Mar 03, 2018 1:10 pm
Thank you for putting the "how to" videos together. They are very helpful.
skyl4rk
Re: #2
Postby ghcoe » Sat Mar 03, 2018 1:18 pm
skyl4rk wrote:Thank you for putting the "how to" videos together. They are very helpful.
Thanks! I hope to get more detailed video up eventually.
George.
ghcoe
Re: #2
Postby Nodrog » Mon Mar 12, 2018 1:23 am
not here
Nodrog
Re: #2
Postby ghcoe » Mon Mar 12, 2018 8:26 pm
Nodrog wrote:Hi ghcoe! Have been meaning to thank you for commenting on my thread...I had read your account of use of flashing, but I have to confess I was too hurried and/or lazy to experiment with that for myself! Shame on me...
Anyhow, you sure are building neat and pretty little teardrops! Have a good one...Nodrog
Thanks, and your welcome. George. :thumbsup:
George.
ghcoe
Re: #2
Postby ghcoe » Sun Sep 09, 2018 8:30 am
In preparation for a upcoming trip I decided that I really needed to lighten up the spring rate on #2. I figure at the most my overall weight to never be over 600lbs. and that is stretching it.
One day while at Cabela's I noticed they had a boat trailer and I was looking at the suspension. It was very similar to the HF trailers, but only had one leaf since it was designed for aluminum boats. I had often wondered if it could be done and after seeing that I though why not go ahead and try it.
So I finally got around to it a few weeks ago. I can already tell a big difference in suspension suppleness.
Spring
Spring off
Springs Removed
It was very easy to do and took me about 30 minutes to do both sides. Once the spring is out you just unbolt the springs at the center and bend back the spring tabs. Remove two springs and then reinstall the bold and put back together.
George.
ghcoe
Re: #2
Postby ghcoe » Fri Sep 28, 2018 8:37 pm
#2 got some big shoes today. With the last trip out I found that I really needed some larger tires to get into the back country. When I got back I looked into options. With a 4 lug hub I was limited to what was available. Without changing the axle this is what I came up with. We shall see how this works on the next trip this week.
The solution? 1.25" wheel spacers https://amzn.to/2y1SrQi and ST175/80D13 tires https://amzn.to/2N7OWxj . The stock tire diameter is 20" and the ST175/80D13 are 24" .
The spacer:
Spacer
Compared tire size:
Tire Size
Fender mod: I had to move the fender up 2".
Fender Mod
George.
ghcoe
Re: #2
Postby ghcoe » Fri Sep 28, 2018 8:40 pm
Finished!
Finished
The spring bolts are not a issue with this setup. Tire bulge to frame is 1.5". Already looks a lot more chunkier. :thumbsup:
George.
George.
ghcoe
Re: #2
Postby ghcoe » Sun Oct 07, 2018 9:13 pm
#2 held up well this last trip out. 800 miles, 4 days and 3 nights with rain, snow, dust, mud, and washboard roads. Spring mod and bigger tires made a big difference in performance!
18 s.png (638.27 KiB) Viewed 3374 times
George.
ghcoe
Re: #2
Postby GPW » Mon Oct 08, 2018 4:20 am
8) :thumbsup:
Re: #2
Postby DaddyJeep » Mon Oct 08, 2018 12:18 pm
That's a cool old Cherokee Chief you have there.
Oh boy.... that white stuff is coming. It's hard to believe we were in the 80's in NW PA over the weekend.
My big hybrid toy hauler with lots of curves build viewtopic.php?f=50&t=69618
155894
DaddyJeep
Images: 65
Re: #2
Postby LostCajun » Mon Oct 08, 2018 6:57 pm
that looks like a good ice box
Building a teardrop or reasonable facsimile thereof
Build thread: viewtopic.php?f=55&t=70932
LostCajun
Images: 46
Re: #2
Postby OP827 » Mon Oct 08, 2018 7:46 pm
How was sleeping in the trailer under the snow, did you have to heat it in any way?
OP827
Images: 405
Re: #2
Postby ghcoe » Mon Oct 08, 2018 8:09 pm
DaddyJeep wrote:That's a cool old Cherokee Chief you have there.
Thanks! If interested you can see it's adventures here https://www.youtube.com/channel/UCYuRx2 ... wVwZJ5oztg .
George.
ghcoe
Re: #2
Postby ghcoe » Mon Oct 08, 2018 8:12 pm
OP827 wrote:How was sleeping in the trailer under the snow, did you have to heat it in any way?
Did not stay in the snow zone on this trip. Temps did drop into the low 30's. It was warmer than a tent, but probably not by much. No supplemental heat on this trip. I may get a small heater to heat it at bed time and in the mornings though.
I cleaned it today and found a few minor issues that I will need to address before next trip.
George.
ghcoe
Re: #2
Postby ghcoe » Thu Oct 18, 2018 6:06 pm
A short of #2 in action https://youtu.be/qGVTPNeZcyM .
George.
ghcoe
Users browsing this forum: No registered users and 25 guests
