Is it advantageous to have a skylight or Stargazer window?
Postby Esteban » Tue Sep 11, 2018 1:25 pm
What are your thoughts and/or experiences about having a skylight or a front facing window in a teardrop trailer?
Some teardrop trailers have a skylight or a Stargazer window installed in the roof, the front facing wall, or the curved area between the front wall and roof. I'm considering installing one in the Benroy(ish) teardrop I'm building to provide more interior light and a nice view of the sky. Some considerations are cost, construction complexity, water tightness, condensation, heat gain and/or loss, daylight, and the quality of the view.
Vintage Technologies sells Stargazer windows in two sizes: 45" x 9" or 40" x 9". They cost $136.95 + $27.50 more for a trim ring. They have tinted glass and do not open. Is it advantageous or worthwhile to buy and install one?
Google images of teardrop trailer Stargazer skylight
I'm considering/wondering whether its nicer to install one on flat on the roof, or into the curved transition area between the front wall and the flat roof. I don't favor installing one in the front facing wall.
Steve - SLO, CA
Esteban
Images: 15
Re: Skylight or Stargazer window experience?
Postby Minics04 » Wed Sep 12, 2018 7:12 am
I have installed the window you are looking at from Vintage tech. I have the 45" x 9" Couple of things to note:
1. My window leaked around the rubber gasket that holds the window in. This has been noted by others on this forum. I used ProFlex RV Sealant to seal the gasket and it is now leak free.
2. There are 2 different trim rings. One is like 2 1/2 Inches and the other is 1 3/4 inches. How do I know? Yes, I had to purchase one of each after ordering the incorrect size. I was not informed about this at the time of purchase. Order the correct size for your wall(ceiling) width.
3. I agree about the added light into the camper, but...the summer sun really warms up the inside! Most of the time during the day I have Reflectix Insulation cut and fitted into the window to keep the sun out. It is bright as soon as the sun starts coming up( I don't mind this), but it might wake you up as others have commented about.
4. Condensation. Keep it as low as possible. We use our camper for 3 seasons. It will condensate and drip on you! Again, I use Reflectix and the fan to control the condensation.
5. Gets dirty and needs to be cleaned often.
6. Water puddles on my window. I wipe it off after a rain. Sealed tight with the ProFlex RV sealant.
7. No instructions on how to install window. I drilled pilot holes for the screws to hold the trim ring into the window.
I'm kinda on the fence if I would install another one in a teardrop. Advantages and disadvantages. I do like the light. Does need a little babysitting i.e. Covered up to keep sun out during day/wiping off puddling water/ cleaning glass
Good Luck!
Minics04
Postby Cosmo » Wed Sep 12, 2018 8:01 am
My trailer has a larger front facing widow which is at about a 60 degree angle so you can use it as a star gazer too. For me it does exactly what you said. Provides good viewing lots of light (light cheers me up without limits).
The window provides endless entertainment looking at nature. I have windows on all 4 sides of the trailer but the front one is huge. It has a pull down skylight shade that is about an inch thick with air gaps in it. Much like you would find on a home skylight.
It’s a big window and I noticed if I have the shade open it conducts cold into the trailer more than with the corrugated skylight shade closed. Its noticeable. Closing the shade virtually eliminates condensation on the colder uninsulated glass surface.
With the shade open I do get a some condensation so I leave the top vent open which passes most respiration moisture out of the trailer. If I am sleeping directly under the window looking up and breathing straight up – I leave the roof vent fan on the lowest exhaust setting and open the ventilation ports I have and I get no condensation on the glass. Meaning I can control condensation with ventilation.
I love my windows and it was a primary factor in my purchase.
=Cosmo
FUN WITH TEARDROP TRAILER VIDEOS
https://www.youtube.com/CosmoWeems/videos
I am an Amazon Associate if you buy from my links I may profit at no cost to you!
Cosmo
Postby jaysul » Wed Sep 12, 2018 11:27 pm
I made my own from a picture window with lexan siliconed to the top to prevent water collection and for the 40$ total i spent on it i love it you can’t beat the stars on a clear night!! Two rain storms and a couple of car washes later and dry as a bone!ImageImage
jaysul
Postby tiiiiii85 » Thu Sep 13, 2018 3:03 pm
Cosmo wrote:My trailer has a larger front facing widow which is at about a 60 degree angle so you can use it as a star gazer too. For me it does exactly what you said. Provides good viewing lots of light (light cheers me up without limits).
=Cosmo
I love vistabule huge window!!
Sent from my ONEPLUS A3003 using Tapatalk
tiiiiii85
Postby Esteban » Thu Sep 13, 2018 7:10 pm
:thumbsup: Thanks for your replies, informative ideas and photos. It's helping me figure out what to do. Please keep them coming with pros and cons and design ideas. My design concept will to be similar to what Minics04's photo shows.
The idea is to have skylight in the forward area, a Fantastic Fan above the entry doors, and a 58" x 26" 160 watt solar panel mounted flat on the rearward flat part of the roof. The partially curved galley lid will be the rear end.
:thinking: Figuring out the best/optimal spacing is a little tricky & still up in the air.
My teardrop plan is to have a Benroy(ish) profile. (Maybe) it will have a 24" curved transition area from the front wall to the flat roof. It will be 5'4" wide and 10'1" long. The hatch design is not finalized and very subject to change. The Galley lid may be circular, or oval, shaped then flatten at the bottom.
:thinking: I'm trying to decide whether or not to mount the skylight/Stargazer window on the top of the roof. My design preference is to mount the skylight/Stargazer window in the front curved area. That may complicate construction. It would reduce spacing constraints. It might provide a nicer/better, somewhat private view toward the front and toward the sky too. Maybe it'd let in less solar heat, depending on which way the teardrop faces the sun while camping.
I'm going to fiberglass (using carbon fiber cloth) & paint the outside walls, roof and hatch surfaces. Not skin them with aluminum. It's cost competitive, considerably lighter weight, strong, easier to build more than 5ft. wide, and will eliminate almost all penetrations that could cause water leaks and/or wood rot.
Steve - SLO, CA
Esteban
Images: 15
Postby Minics04 » Fri Sep 14, 2018 7:09 am
I positioned my stargazer window directly above our heads when laying down for a clear line of sight to the sky. FYI.
Minics04
Postby tony.latham » Fri Sep 14, 2018 9:14 am
I'm going to fiberglass (using carbon fiber cloth) & paint ...
Why carbon fiber instead of glass? It's been a few years since I bought carbon fiber and I would think it would prohibitively expensive for a project of this size. Has something changed?
:thinking:
Postby Pmullen503 » Fri Sep 14, 2018 12:30 pm
Carbon fiber is overkill. You'd be better off spending the extra money on better plywood. I'd pop for marine plywood before spending more on carbon fiber.
Pmullen503
Images: 67
Postby Esteban » Fri Sep 14, 2018 2:21 pm
I drive a Subaru Forester with a tow rating of 1000 lbs. for a trailer without brakes or 1500 lbs. for a trailer with brakes. My trailer will have a Dexter #9 axle with electric brakes. The goal is to build a 5'4" wide x 10'1" long trailer that will weigh less than 1200 lbs. I'm being careful to save weight where I can reasonably do so.
I'll use epoxy, carbon fiber cloth and 1/8" plywood for the outside roof and wall skins to help keep my teardrop's weight in check. Carbon fiber cloth will considerably strengthen thin plywood. I've estimate that fiberglass provides about a 90% weight reduction compared to an aluminum skin. A fiberglassed skin should be more water and rot resistant too. I bought discounted carbon fiber cloth from uscomposits.com. The ~$220 cost to use carbon fiber cloth is about $150 more than using fiberglass cloth. It's well worth it for the 50% weight savings (~60 lbs) achievable by using 1/8" plywood instead of 1/4" plywood for the roof, walls, and galley lid.
:) Do I NEED to use carbon fiber cloth to have a lighter weight outer skin? Maybe not. But for only about $150 more than using fiberglass cloth I decided the added strength and weight savings are well worth it to me. Part of the cost will also reduced/offset by the lower cost of using 1/8" plywood instead of 1/4" plywood, or two layers of 1/8" plywood for the curved sections of the roof and galley lid.
:thumbsup: All in all using carbon fiber cloth adds very little, if any, extra construction cost.
The walls will be built with 1/8" Baltic Birch plywood. The roof and galley lid will use good quality 1/8" x 4' x 8' plywood purchased from a hardwood supply store. Not cheap quality luan plywood.
The cost to fiberglass, even with carbon fiber cloth, the outside skin compares very favorably to the total cost of aluminum sheets, trim pieces, sealants, and fasteners.
High quality manufactured teardrop trailers can easily cost $20,000 or so when useful upgrades and nice options are included in one. My goal is to build a custom teardrop with similar, sometimes even higher quality parts and construction materials. My teardrop will have solar power and some fun goodies (potentially) like a skylight for a small fraction of that cost.
Please keep sharing pro and con ideas, experiences, construction details and photos about skylights.
:thinking: I recently discovered information about Heki Rooflights sold by Dometic. Some open wide enough for you to stand up in the opening. They can combine the best features of a Fantastic Fan and a skylight in one fixture. They are pricey imports from Europe. Google Search results for Heki Rooflights
Steve - SLO, CA
Esteban
Images: 15
Postby Esteban » Sun Sep 23, 2018 11:16 pm
I'm favoring installing a Stargazer window in the (Benroyish) curved transition area between the front wall and the roof. The front curved area will be 64" wide and (probably) have a 24" radius curvature. The wall/curved area/roof will be 1-3/4" thick. I'd also buy the 1-13/16" trim ring to install the Stargazer window
:thinking: I wonder how easy, or difficult, it will be to construct the window opening, then install and properly water and weather seal a Stargazer window in the 24" curved area?
A Google search for Stargazer window images shows helpful examples for how it's been done.
(Potentially) installing a Stargazer window in the front curved area helps provide adequate room on the flat roof area for a Fantastic Fan and a solar panel which are important features.
Steve - SLO, CA
Esteban
Images: 15
Postby eLink » Sun Nov 18, 2018 1:00 am
I would also prefer to have the skylight located on the curve, so that water flows away from it rather than pond on it. Commercial manufacturers are doing it, but it looks like a slight "dimple" is created in the skin where it meets the flat edge of the window. Check out the Youtube videos from Oregon Trail'r... they offer some good hints.
eLink
Images: 142
Re: Is it advantageous to have a skylight or Stargazer windo
Postby GPW » Sun Nov 18, 2018 7:41 am
My “moon-roof” was free and Leakproof … Always a Nice view … ;)
We used to make ‘Kustom Vans “ back in the late 70’s and people would come in wanting a moon roof like they saw on the California vans , but here with the rainy weather , they usually always leaked . :rainy:
FSmoonfin2 copy.JPG (104.41 KiB) Viewed 2913 times
Users browsing this forum: Bing [Bot], Google [Bot], tony.latham and 2 guests
