Looking to lay new flooring over the existing 5/8' plywood in my 6x10. The current floor is a bit weak, and I would like to have something that is:
a. Stronger
b. Looks better
c. Easy to clean
Any suggestions?
McDave wrote:It may be better to just replace the 5/8" with new 3/4". Then finish with flooring of your liking. Is the trailer new or used? The reason I ask is that cargo trailers tend to get used hard, often more than designed for. You might want to get under there and inspect the crossmembers and also be sure the screws that secure the floor to the members are there still. I have seen crossmembers that were bowed more than an inch and had pulled the screws from having a heavy load that was concentrated in the center.
McDave
