Tomterrific wrote:It may be as simple as a C channel to hold the springs. Bolt the C channel with the springs/axle to the frame.
The trailer will be higher with leaf springs.
Ad says needs wheel bearing. The spindle may be damaged by the bad bearing rendering the axle unusable. Maybe that is why the question?
Tt
NO David! wrote:Seems like a fair bit of work to swap the axles from torsion to leaf. I ordered leaf from the factory over torsion, to gain 4" ground clearance.
Here's a kit to lift a factory installed torsion axle set. You get the benefit of torsion suspension, and some more ground clearance that you are after too. Seems a pretty straightforward install.
http://www.airforums.com/forums/f437/dexter-torsion-axle-lift-kit-102393.html
a video:
https://www.youtube.com/watch?time_continue=3&v=7QVstjocHps
swoody126 wrote:Did the same thing(replaced torsion w/ leaf) on an old Starcraft tent camper to gain ground clearance for back country camping
rebar wrote:Ive read much more about converting leaf to torsion, but yeah.. Does anyone have knowledge about converting a cargo from torsion to leaf?
I imagine they build the frame differently between the two? Or do they just add a few structural members for the torsion axle to bolt to and the frame rails are in the correct same place as the leaf spring frame?
This is the trailer in question..
https://bn.craigslist.org/tro/d/haulmar ... 10503.html
Thanks!
tony.latham wrote: The torsion axles ride much better than the bouncing springs (both loaded and light). So my question is, why?
working on it wrote:I made my own assemblies from 1/4" angle + 3/16" flat bar stock, and welded/bolted them on to my existing frame.
Though I spent considerably more time and money (buying 2 welders and working many hours in fabricating--it was my first from-scratch welding project) than if I had bought these, it was worth it just to make it myself. But, I was also strengthening my frame at the same time...if your frame is strong/intact, then the bolt-on assembly would be perfect for you to use, IMHO.
Leaf is more reliable for off road and you can mix and match springs and axles and upgrade modify later. Ive read some discussions inducing a few successful off road trailer builders who said they tried torsion, but leaf was less likely to fail. But then went independent.
tony.latham wrote:Leaf is more reliable for off road and you can mix and match springs and axles and upgrade modify later. Ive read some discussions inducing a few successful off road trailer builders who said they tried torsion, but leaf was less likely to fail. But then went independent.
The Army apparently disagrees with the reliability argument. All new U.S. Army "utility" trailers are built with Dexter Torflex torsion axles.
