I also notice my driving habits are better as our TV is also our only vehicle. Looking back thru our travel log, I have gained an average 2 MPG in my non-towing local travel on a 19 gallon tank, might not seem much until you look at the long term.
Second thought - how many are using a TV that is factory setup for towing or have they modified a TV and hoped it would be ok based on something someone said. How many have check all the GVW's and actually measured things? I run 100 pounds over on the whole total weight when I am going out on a long trip so I tend to watch the numbers over the 'lights'.
I have a factory tow package, transmission cooler and the manual schedule is fluid change at 100,000 miles but something I found:
- image.jpg (43.34 KiB) Viewed 4276 times
I don't know what temp my idiot light comes on at but I'd rather know that temp so I can schedule an early change as I have hit 200 degrees several times and it makes me hold back even though I am cruising at 55.
