Thelgord wrote:This is amazing. I like the idea of the fiberglass screen rather than the canvas. This gives me so many ideas!
[edit]
This should be a sticky ...
[/edit]
jondecker76 wrote:Thelgord wrote:This is amazing. I like the idea of the fiberglass screen rather than the canvas. This gives me so many ideas!
[edit]
[/edit]
If I were to build a foamie trailer, I'd use aluminum screen. I really liked using the fiberglass screen because it was so easy to work with and it made a lot of sense for cabinets, but nothing that I've tested comes close to the strength of aluminum screen! Yes, it's much harder to work with (and to hold down flat while the gripper dries), but one of my test panels supported 80lbs with almost no noticeable deflection on a 12"x24" panel supported at each end lengthwise. For comparison, the same sized test panel made from canvas/wood glue bowed about 2" with 20 lbs of weight added and failed completely at 35 lbs.
One thing that I wanted to test but never got to was multiple layers of fiberglass screen. Perhaps 2-3 layers would catch up to the aluminum in terms of strength?
fotooutdoors wrote:I'm curious about aluminum screened foam's ability to deal with thrown road debris compared to canvas. I wonder if they would tend to delaminate more since the screen obviously doesn't have as much give perpendicular to the plane. Regardless, if I ever do pursue my crazy ideas for a gull wing ttt, I will seriously consider using it as the inner on the roof, which I want to make load bearing.
Also, really interested in the bedliner as a protective skin that is easy to clean(mainly inside). Several folks have used it with wood construction, but I haven't found anyone who uses it on foam.
Sent on my phone. Pardon the autocorrect.
[edit]
[/edit]
