GPW wrote:So you’re making a teardrop trailer on top a big Battery … ? Well then, that’s a new idea … So do you plan on Camping with it or just a battery tow … I assume weight is everything …so you’d want something simple and light … In that case you could make your own door to suit your needs … All comes down to your labor vs, your budget … check the weights of storebought doors … Simple and clean ( streamlined Lightness ) is the best for electric endurance …
KennethW wrote:Range extender sounds like a good idea. Why not just use a generator in the teardrop? I would think a inverter generator could be adjusted to your charge voltage.
GPW wrote:OK, COOL !!!
Since I had all my materials in the stockpile , the whole job cost me nothing but a few hours of time , but saved me at least $500.00 or likely much More had we gotten someone else to install it …
Bottom line : Doors are EXPENSIVE ... Whether house or trailer, storebought or homemade … Take good care of them and they’ll last a long time , defraying the initial cost per year … Doors are much like trailers , Water that leaks in unnoticed can do major damage over time …especially if any wood is involved ..
