The Coddiwompler
The Coddiwompler
Postby eLink » Sun Feb 03, 2019 9:10 pm
Welcome to the build journal for The Coddiwompler!
(Coddiwomple (v.) Origin: English Slang Word. Definition: To travel in a purposeful manner towards a vague destination.)
I figure that it is time for me to stop over-thinking the design and begin the actual building! My progress will be slow, because I also have a ton of other projects that need to be done around the house. But, I hope to get this done in about a year... maybe in time for the 2020 ski season.
The design is based on the Generic Benroy, and it will be 5' wide x 9' long, plus 12 inches of over-tongue storage. It will be 4'-6" tall with 45" cabin head-height.
It will be built on the NT Ironton 5x8 trailer with the typical modifications: Frame width will be cut to 58", Leaf springs will moved back about 6 inches with axle positioned above the spring, tongue extension bar will be added, and larger wheels.
I'm leaning toward solid 3/4" walls for simplicity, but the roof and floor will be insulated. The interior surfaces will be just finished plywood, with minimal, or no exposed hardware, trim or fasteners.
I just received the trailer from Northern Tools. My nearest store is like 2000 miles away in Ohio or something, so it had to be shipped. $198 big ones! They did throw in a $50 gift card! But I am finding that to be useless because none of the tools I'm interested in can be shipped to CA. Oh well.
I'll post my next batch of photos when I have the frame built.
Enjoy!
The Profile
Plywood layouts
1st Step: Build the trailer. Well, maybe clear some room in my garage first.
eLink
eLink
Re: The Coddiwompler
Postby soapcreek » Mon Feb 04, 2019 7:34 pm
Good luck and look forward to seeing your progress.
soapcreek
Postby redbicycle » Mon Feb 04, 2019 8:39 pm
Order some wiring or a spare tire or sandpaper from Northern tool. $50 is consumable items is easy on a trailer build.
redbicycle
Postby eLink » Sun Feb 10, 2019 11:13 am
Fun with Sketchup 2019. It now has solid section fills and line styles!!
Notice the dotted spar lines
eLink
eLink
Postby eLink » Wed Apr 17, 2019 11:18 am
Started chopping the cross-members to reduce width of trailer to 58 inches. I cut an inch off of both ends, and re-drilled the bolt holes. In retrospect, I should have cut 2 inches from one end only to reduce the amount of re-drilling.
Chop-saw
I think I am close to finishing the design. I increased the height from 54" to 60". I'm a big dude and I need the headroom!
I have also decided that I need 42" high doors because I would hate having to crouch to see out the windows, and I prefer not bonking my head all the time. I got a price from Challenger for almost $700 each! So I guess will be building them myself. They will look better anyway. I also re-positioned the door to allow me to more easily sit and swivel into the cabin.
eLink
eLink
Postby tony.latham » Sat Apr 20, 2019 7:50 pm
Keep the bottom of the door opening halfway up the mattress so that when you are sitting there your but won’t be on the door frame.
Postby eLink » Tue Apr 23, 2019 10:07 pm
Thanks Tony. I am going to set the door sill at about 2 1/2 inches above the floor... maybe lower if I add an interior doorstop, which, I guess, will have a 5/8" lip. I was considering a 4" folding mattress, but If the door sill bites into the legs too much I suppose I'll have to find a thicker one.
Here is my sidewall/ door sill detail, kinda cobbled together from all the information found in these forums...
eLink
eLink
