Padilen, Howdy;
Good to hear from ya. Mend well, and take your time, no need to rush.
Check in from time to time, please.
hank
Padilen wrote:Just healing slowly. And weather has sucked, sub zero days then rain. It's goofy.
Thanks for checking.
flboy wrote:Padilen wrote:Just healing slowly. And weather has sucked, sub zero days then rain. It's goofy.
There you are... Glad to hear you are healing! The weather is funny this year! I am wondering if McDave has dug out yet also. Sounds like they were hunkered down there in MT for a while.
Spring will be here before you know it. Take care!
Padilen wrote:Feeling well enough to want to get back on my remodeling. Of bike and Taz. But I have 8 more days of restrictions. Then I have to be "sensible".
Looking for a better quality terminal block for 12 volt. Im thinking of, changing angle of PD4045. Turning it out to face rear of Taz. That will allow me to redo, shelf/ cabinet,ac & fridge and maybe make a closet, across front. Hopefully mount a heater too. And still allow access to PD4045. I think if I make bottom cabinet doors slide/or removable. A bikes front tire will still go up enough to haul 2 bikes.
Thanks, I'm in Michigan so we never count on good weather .hankaye wrote:Padilen, Howdy;
Good to see you posting again. Also good to hear that you are closer to a full release by the Doc.
Weather should (?), be getting better soon. Keep on taking it easy till the Doc says it's OK to get
back to nermal. Ya don't need to go through all this again, right?
, soon,
hank
Padilen wrote:Thanks, I'm in Michigan so we never count on good weather .hankaye wrote:Padilen, Howdy;
, soon,
hank
Ok here is the "extra" white terminal block. It is the type I like as it's just wire in and tighten screw. But these are cheaply made and break. As seen in photo, with the broke and missing pieces.
The black is the type I don't like as it needs a terminal on each wire.
Uh oh. What did you do?Padilen wrote:Did some demo, not sure if it's progress or two steps back.
Trying to face my power center out to the front. So wires may not reach. I did have some slack in most. But the ones I don't will be hard to redo. I'll take a pic when I run out to check boiler.flboy wrote:Uh oh. What did you do?Padilen wrote:Did some demo, not sure if it's progress or two steps back.
Users browsing this forum: Google [Bot] and 8 guests
