Hi everyone. I'm not having much luck buying a used CT in the configuration I want, so Ive found a few builders who will build it for me. The latest manufacture, Pace Setter, has gained my trust enough for me to seriously consider ordering one.. Ive also considered featherlite and Jensen trailers. Both custom builds. http://www.komfgco.com/
The last decisions I need to make are about what brand, and what size windows and door/screen I want. Does anyone have a short list of the best RV windows and doors available, and are there common sizes I should use to make it easier for replacement if the company I use goes belly up years later? I dont like the door placement on the V nose on the plans and would rather have it close to the wheel.
And second, the >100 gallon water tank.. I don't know the spacing between the frame rails yet but guessing about 55", and pace setter will leave enough space after I tell them where, but I need to choose or have a custom tank built. Has anyone had a custom water tank built, and what company's should I consider? Ive also decided to use a composting toilet so no black tank needed. But I'm leaning on not having a grey tank and just dump it on the ground 20' away with a hose. But if I ever camp in a camp ground, I don't think that will fly.. Should I plan on a grey water tank to?
Thanks!
