It's super quiet. Except for the fuel pump. From what I hear, all the brands are the same. It's a constant tick, tick, tick. Still working on that. But the unit itself is more quiet than a regular fan.
Sent from my SM-N950U using Tapatalk
Atomic77 wrote:It's super quiet. Except for the fuel pump. From what I hear, all the brands are the same. It's a constant tick, tick, tick. Still working on that. But the unit itself is more quiet than a regular fan.
Run the unit outside the cabin, or the fuel pump, or both? The fuel pump is fine to run outside because its sealed. But nothing else unless it is an Eberspatcher, Webasto or Planar. The one I have is great, stowed in an inside compartment. But outside is not good because the brains of the unit (electronics) are not up to the task. The name brand electronics are sealed in epoxy of some sort. These are not.GeekFisher wrote:Atomic77 wrote:It's super quiet. Except for the fuel pump. From what I hear, all the brands are the same. It's a constant tick, tick, tick. Still working on that. But the unit itself is more quiet than a regular fan.
Well I plan to run mine outside of my cabin so might be good even with the ticking of the pump. I also kind of dropped the galley a/c Idea and will likely hack a 5000 unit this way viewtopic.php?f=30&t=44561
Yes. I saw the same video. From reading a whole bunch of forum posts about it, this works sometimes and sometimes it doesn't. Apparently all pumps are not created equal. They can be replaced for around $15-20, so I thought I might try one of the name brand pumps. I quickly changed my mind as the cheapest one was around $180 and as high as $300. One of the issues for me is, going down the road, bouncing around like a 4.9 on the Richter Scale... I prefer it to be securely mounted.featherliteCT1 wrote:I saw a video where a guy suspended his fuel pump off a 2 inch piece of rubber strip so that the pump was not transmitting sound through any solid mounting surfaces. Afterwards, the pump could hardly be heard.
Hey, thanks Tony. Much appreciated! I'm still not done, trying to get all the upholstery finished so I can run wires for the controller. I was concerned about buying the cheaper unit, but now I know I am happy with the concept, so swapping in a Webasto or some such other will be very simple. But for now, she purrs like a kitten and I recently spent two nights in freezing temps and slept comfortably with nothing more than a sheet. It's a big difference from the ceramic heater - there are no cold spots, it is a very even heat and it's nice and dry. It seems to like the Kero so I'll stick with that when possible.tony.latham wrote:Michael:
I watched your video and would have bet a million your install was clean as a new windshield. I wasn't wrong.
OP827 wrote:Maybe we will soon see an affordable cook top forced air vented stoves on diesel too.
bdosborn wrote:OP827 wrote:Maybe we will soon see an affordable cook top forced air vented stoves on diesel too.
You can get all of the above except for the affordable part.
Wallas DT85
I can't find a price for one on-line so I'm sure the price will knock your socks off.
Atomic77 wrote:Thanks Oleg, much appreciated. I'm only sad that winter is gone now so I can't use my heater
OP827 wrote:bdosborn wrote:OP827 wrote:Maybe we will soon see an affordable cook top forced air vented stoves on diesel too.
Wallas DT85
https://wallas.ca/product/85xc/ - there is a price in Canadian dollars, install kit is not included.
bdosborn wrote:
