GPW wrote: ... and we’re back !!!
The little milkhouse heater was run from a 50’ extension cord and into the FS electrical system/GFI ...Worked fine ... But I’m sure I lost a bit of power over the extension cord length , a 25’ cord would likely be better, providing more power to the heater, and faster heating ..
Sitting there just doing nothing but munching on some leftover bread pudding and a Diet coke (that makes sense huh ? ) , I really noticed how HUGE this thing is inside... Sitting on the floor cushions, felt like I was in a blimp hanger... The thought occurred that I might be pushing the limit of what could be called a Tiny travel trailer ...
GPW wrote:Well then , the ice /rain/shush stopped .... finally ... Now it’s just COLD and clear ... mid 20’s ... supposed to stay that way for a day or two then back to 72F on Saturday ... TG !!!
Funny , made a couple pots of beans yesterday .... Put it in containers for the freezer, then put them outside ... a couple hours , they were Frozen solid ...Then moved them to the freezer...
GPW wrote:We wanted to show how the fabric skin shrinks over time and exposure ... These close up pics are ~ 1/16” exposed primer where the seams pulled apart from shrinking .... only two we found and on the nose . We’ll fix those before the intense FS washing/Fall cleaning coming up , likely tomorrow ...
note: seams with generous overlap did Not show any signs of separation.. and another good reason for the reinforcing strips underneath ...
GPW wrote:We got to spend a pleasant afternoon with Kenneth W and his wife Dixie ... We talked and talked about foamie' trailers , and Ken did a really Nice job on his All Foam Foamie ... Sad to see them go but we had a nice opportunity to get acquainted ... And here are the Pictures ...
GPW wrote:Brushing on epoxy sure would be easier , but I was hoping the pressure of the “squirt" would drive the Mix into all those tiny little places ... I’d really hook up a spray gun and compressor if I had a lot to do , but it’s hardly worth the effort for just a couple little spots ... This way I can just lie on my back under the trailer and just spray what looks like it may benefit ... Easy !!! And that will only be around the edges next to the newly to be installed drip edge, so what doesn’t “take hold" will merely run off ... Trying to keep it as simple as possible .... Getting Old now !!! Things not as easy as they used to be ...
rjgimp wrote:... I wonder about the possibility/feasibility of safely rolling the thing onto it's side.
GPW wrote:And at 70 now , I’m not getting any younger...
