low277 wrote:I just noticed that you are from Minnesota also. I am very curious about how well your new heating system works. I have been around the Webesto units, which are very expensive but work well. So if yours works well I would certainly be interested in getting one.
Very nice job on your trailer!!
low277 wrote:Thanks for the update on the diesel heater! I see another member getting ready to install one as well.
I also like your dual sport/enduro motorcycles. Any information on them?
kirkupnorth wrote:It's been pretty wintry this past week in northern Minnesota. On Tuesday we had four inches of snow, and it's been cold all week. Definitely time to finish up the camper tasks needed for cold weather camping!
We started with finishing the under floor insulation. We used 2" thick, foil backed rigid insulation. To install, we cut insulation pieces to fit between the steel crossmembers of the floor. We then foil taped all of the pieces to the under carriage. We also bought some big washers so we could screw the pieces up into the subfloor.
We finished up the diesel heater install. We wanted the ability to continue using that cabinet for storage, so we built a box around the heater. If we ever need to get to it, we just need to remove a few screws.
The heater came with a round black vent cover. We installed that into the door. We thought we'd hate how it looks, but it's okay. The door opens and closes easily, and fits over the metal hot air vent just fine.
This little diesel furnace works great!! We tested it yesterday morning. At 10:00 AM the temperature inside the camper was 24 degrees. We turned the furnace on to warm things up. We went back out to check progress one hour later. At 11:00 AM the temperature inside the camper was already up to 65 degrees. We're really pleased with that performance.
The final step, of course, was a combination smoke/CO alarm. We chose this one for several reasons: It's small (4 inch diameter and 1-1/2 inch height), it uses AA batteries, and it has a photoelectric sensor for smoke and an electrochemical sensor for CO. If interested, it's at Amazone here:
https://www.amazon.com/gp/product/B07D5TQQNV/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I still need to make some insulated window coverings-- maybe I'll work on that this weekend. We're excited that we can now use the camper in cold weather.
norcal2 wrote:You did a great build I should have started with the taller 6 x 12 mine is a little short...just FYI my RV failed a pre purchase inspection due to a home C02 sensor installed, they are not rebust enough and take vibration as the RV rated ones do, (per the inspector) so i had to buy a new RV rated one, just want to let you know, great build i will keep following, my 6 x 12 has worked great the last few years just got done installing some solar to keep the batteries mantained...cheers!kirkupnorth wrote:It's been pretty wintry this past week in northern Minnesota. On Tuesday we had four inches of snow, and it's been cold all week. Definitely time to finish up the camper tasks needed for cold weather camping!
flboy wrote:Nice job on the step. That is on my list also. I am just trying to decide how much drop I want. I do not want a double step, but need something before I break my neck on the portable step.
