HandiCramper
Re: HandiCramper
Postby twisted lines » Sat Jun 08, 2019 7:31 pm
Atomic77 wrote:Coming along nicely and looks great!
Sent from my SM-N950U using Tapatalk
Thank you!
Not to much damage today when I rolled it :lol:
It's taller then I am. Not sure I will roll it for the other side :?
5.5 X 10 Flatback Benroy in a pile,
And it's growing!
twisted lines
Re: HandiCramper
Postby aggie79 » Sun Jun 09, 2019 8:11 am
Very nice! Great craftsmanship!
Sent from my iPhone using Tapatalk Pro
For more on our Silver Beatle teardrop:
Images: 684
Re: HandiCramper
Postby twisted lines » Sun Jun 09, 2019 4:42 pm
aggie79 wrote:Very nice! Great craftsmanship!
Thank you :D
And it's growing!
twisted lines
Re: HandiCramper
Postby twisted lines » Mon Jun 10, 2019 2:37 pm
Little Gorilla Glue Back in bidness!
Pretty tough but wouldn't support the weight
broken Foam.jpg (71.59 KiB) Viewed 3327 times
Yea I am flipping for the other side.
first side.jpg (75.6 KiB) Viewed 3327 times
And it's growing!
twisted lines
Re: HandiCramper
Postby twisted lines » Sat Jun 15, 2019 8:56 pm
Still plugging away second side is glued on, the 65-1/2" top glued together and have found this is not something to do at my home :lol:
I am going to use it but need something to fill some voids prior to the monstaliner? (Tight bond 3 it is)
Started on the Axle today, and read, asked inside tire to frame clearance, and got 3/8" to 1.5" recommendations, I am at 83.5 wide in my head so want to squeeze it but not 3/8" what's too tight.
My bad I searched on this site and aggie 79 had just the number I wanted to find; Makes it 83.5 wide ;)
Front Radius 5x5 1/8" B Burch Doubled up still undecided :? any thought what to use to bond them together would be appreciated.
Second side.jpg (79.34 KiB) Viewed 3284 times
bulb joint.jpg (62.47 KiB) Viewed 3284 times
And it's growing!
twisted lines
Re: HandiCramper
Postby twisted lines » Fri Jun 28, 2019 4:03 pm
Last of the outside skins is on, as well as tires on the ground.
Now I have a day or two to shop for a tongue jack it's driving me more nut's not having one then I thought it would.
Last outside skin.jpg (94.25 KiB) Viewed 3242 times
And it's growing!
twisted lines
Re: HandiCramper
Postby twisted lines » Fri Jul 19, 2019 4:16 pm
Still plugging away; two steps back and one forward :lol:
In poly.jpg (111.15 KiB) Viewed 3101 times
And it's growing!
twisted lines
Re: HandiCramper
Postby S. Heisley » Fri Jul 19, 2019 4:44 pm
twisted lines wrote:Still plugging away; two steps back and one forward :lol:
That's the way I felt when I built mine; but, it was so-o-o worth it!
Keep going. It looks like you're doing great!
Images: 491
Re: HandiCramper
Postby OP827 » Tue Jul 30, 2019 6:34 pm
Great work! Are you covering BB ply in epoxy with light glass cloth before finish?
OP827
Images: 380
Re: HandiCramper
Postby retep » Wed Jul 31, 2019 5:08 am
You are doing a fantastic job!!!! Watching your every post. I am about to start on my TD soon. Thanks for the inspiration.
Cheers
Peter
:beer:
retep
Re: HandiCramper
Postby twisted lines » Wed Jul 31, 2019 11:22 am
Thank you and hope to get a better look at yours soon!
And it's growing!
twisted lines
Re: HandiCramper
Postby twisted lines » Wed Jul 31, 2019 11:29 am
OP827 wrote:Great work! Are you covering BB ply in epoxy with light glass cloth before finish?
I am not using epoxy, (polyurethane) Caulk then 3 coats of High Gloss then Monstraliner. To old and crippled up for Fiberglass.
And it's growing!
twisted lines
Re: HandiCramper
Postby twisted lines » Wed Jul 31, 2019 11:36 am
Cheers
Peter
:beer:
Thank you, Don't start with a floor like mine!
Best wishes on what ever you come up with.
And it's growing!
twisted lines
Re: HandiCramper
Postby OP827 » Wed Jul 31, 2019 2:46 pm
I recall reports here of bedliner separation from plywood after sometime. Don't remember the build names though, sorry.
Sent from my Moto G Play using Tapatalk
OP827
Images: 380
Re: HandiCramper
Postby twisted lines » Wed Jul 31, 2019 5:29 pm
I can picture a build or two, I only remember it was different brand's not monsterliner, Thank you for checking and making aware of possible flaws, I need can sure use guidance :thumbsup:
Nice build you have going.
And it's growing!
twisted lines
