Salem Vent question
Salem Vent question
Postby Carolina_coast99 » Tue Jun 25, 2019 7:40 am
I did not find a lot of information on the site specifically about Salem vents, so I thought I would ask... :D
When I place my trailer order; I plan to possibly substitute a front window with a Salem vent (metal construction with open and close capabilities) for a vent path of fresh air. I was only originally considering the front window for its ability to crack open when I need cross flow circulation to my rear window located in the rear trailer bathroom area; or if the trailer ends up being "sealed" to tight after my insulation work. (There will be no roof vents). One drawback i can see- there is no screen for bugs. Is this a big deal, do bugs (flying or crawling) make their way through these while open- especially if I were to leave open during storage? <or a mouse..?>
Also:
Does water come in through the vent while open or closed? When driving down highway, or just sitting while camping?
Would it be advised to mount in a horizontal fashion as opposed to the standard vertical mount in an effort fo reduce chance of water intrusion? - I will not be using this in the standard sense with one mounted high and one low on opposed walls- for air while going down road....
Thank you in advance for any input!
Carolina_coast99
Re: Salem Vent question
Postby working on it » Tue Jun 25, 2019 10:50 am
* I considered using these "Salem" pop-up vents, but wasn't quite sure of how waterproof they would be.
I wasn't sure if leaving these vents open full-time was OK for waterproof use
pop-up Salem vent from etrailer.com.JPG (48.1 KiB) Viewed 2690 times
* Instead, I chose another type I was familiar with, a steel vent that I knew could be left open, and remain waterproof under all conditions. When I purchased my four, these were offered in a galvanized finish, which was OK for my exposed-hardware, post-industrial motif.
these now come in white, which I guess could be painted to match other color schemes
sidewall-mounted Polar waterproof vent, from etrailer.com.JPG (45.44 KiB) Viewed 2690 times
* I use three for ambient air venting (two in the cabin, and one in the galley), and installed plastic screen-door mesh under the butterfly opening inside, to ward off insects. I leave them open all the time, sometimes reducing the openings in the cabin vents (to reduce any loss of cooling, when the A/C is used). They remain waterproof after many years. The fourth vent is actually used as a cover for the A/C exhaust vent, so it's not required to be waterproof or insect free. The two cabin vents have reversible, two-speed 12vdc computer case fans on swing-away mounts, that I can use for forced ventilation if my 110vac main fan & A/C are not being used.
multiple usage of sidewall-mounted vents
usage of rain-proof vents.jpg (203.08 KiB) Viewed 2690 times
* I noticed these vents on some over-the-road trailers (when I was in shipping-receiving), and they never showed signs of water intrusion from highway driving, whereas some other types did. Since they were intended for use on metal-walled trailers (probably not for my 3/4" plywood-walled TTT), I'm sure they would work well in your conversion.
173193172890148599
working on it
Images: 457
Postby Carolina_coast99 » Tue Jun 25, 2019 11:09 am
working on it wrote:* I considered using these "Salem" pop-up vents, but wasn't quite sure of how waterproof they would be.
I like that 10x12" vent a lot. And good price. Thank you.
Carolina_coast99
Postby Carolina_coast99 » Tue Jun 25, 2019 11:12 am
How would the hole be cut out on an aluminum skinned trailer with plywood brace backing between ribs? Would a hole saw that big be the best route?
Carolina_coast99
Postby hankaye » Tue Jun 25, 2019 6:59 pm
Carolina_coast99, Howdy;
Those "Salem Vents" you show in the top pic. in your 1st post is exactly what are used
by Paccar when they assemble Peterbuilt and Kenworth tractors. They are the rectangular
vents on the sides of the sleepers. They work great.
hank
hankaye
Postby working on it » Tue Jun 25, 2019 7:37 pm
Carolina_coast99 wrote:...How would the hole be cut out on an aluminum skinned trailer with plywood brace backing between ribs? Would a hole saw that big be the best route?
* I cut all my larger openings (vents, windows, A/C mounting hole, and even my door cut-outs) using a Rotozip with a circle guide, or with a guide jig for the larger rectangular openings. I tried free-handing, but it was hard to keep a straight line. That was thru one thickness of 3/4" plywood (or two when I cut out the doors at the same time, stacked together). I've also used the Rotozip metal cutting bits when cutting race-car metal interiors, so I know it does work (though the guides are a must).
Rotozip guide, and bit for metal.jpg (70.03 KiB) Viewed 2629 times
173193172890148599
working on it
Images: 457
Postby Iconfabul8 » Tue Jun 25, 2019 10:52 pm
I cut the shape out of the wood first, then use the wood as a guide for the roto-zip. Run the smooth part of the shank against the wood and away you go. Oh, drill a start hole first.
Build Post pictures are from
More in depth description
Iconfabul8
Images: 14
Postby Carolina_coast99 » Wed Jun 26, 2019 7:16 am
I hadn't seen one of these. Thank you. I'm getting one! :)
Carolina_coast99
Postby Carolina_coast99 » Wed Jun 26, 2019 7:18 am
Iconfabul8 wrote:I cut the shape out of the wood first, then use the wood as a guide for the roto-zip. Run the smooth part of the shank against the wood and away you go. Oh, drill a start hole first.
I Really appreciate the tip here! Thanks.
How did you anchor the plywood to the thin aluminum initially? Is the wood supported by the insulation and just glued to the aluminum skin...?
Carolina_coast99
Postby Carolina_coast99 » Wed Jun 26, 2019 7:23 am
hankaye wrote:Carolina_coast99, Howdy;
hank
Great, thank you.
Would it be reasonable to just have the factory install? I'm trying to envision how the insulation and final interior layer will work with a pre existing vent... or would it be wise to wait and install the vent after I add 2" of insulation ...?
Carolina_coast99
Postby Iconfabul8 » Wed Jun 26, 2019 11:32 pm
Carolina_coast99 wrote:I Really appreciate the tip here! Thanks.
The wood inserts were screwed to the inside sheeting. The inside sheeting was then routered using the wood inserts again as guides. I may have put some silicon between the aluminum siding and the wood inserts, can"t remember for sure. It would definitely help keep the metal shavings out from between the wood and aluminum. The secret to this method is that you have to make sure the wood inserts are exactly the same size(thickness) as the foam and studs.
Iconfabul8
Images: 14
