I started my vacation time 3 days ago. So I've been working on the tear for most of each day. That's the good news. The bad news is that 96% of the work has been filling holes and defects with wood filler. Then sanding away for hours. Just like working in a body shop with the noise and the dust. Facemask respirator is mandatory. So are long showers at the end of the day to wash off the dust.
Just amazing how many nail holes, staple holes, screw holes, plywood defects, gouges, and nicks there are. Really don't notice it much while you're building. When you're hunting them down for wood filler application, they seem to be everywhere. I'm getting the camper extra smooth and filled as I am going to be doing a PMF exterior. Don't want the fabric to show through the surface flaws. I've got a good 80% of the body work done and it looks real good.
Took a day off from sanding and started the PMF work. Decided I was going to use a thin fabric for the door edges, door jambs, and galley hatch wall water rails. I've cut an old 100% cotton bed sheet for the fabric. Then I started with the edges of my entry doors. Very happy with the thin fabric. It's gluing down flat and smooth. Took the mild curve at the top of the door without bunching up.
Once this is dried I will soak the material with a diluted water/glue mix and let that harden. Then I will come back and hit the edges of the interior wood door panel with my hand sander. That will flush trim the PMF to the interior door panel.
- pmf1a.jpg (77.38 KiB) Viewed 3408 times
- pmfa.jpg (82.52 KiB) Viewed 3408 times
