Did you bolt or weld the axle flange to the frame or did you use the Flexiride side mount hangers ?
Be careful to not build up too much heat from welding as it can flex the chassis some.
tony.latham wrote:Be careful to not build up too much heat from welding as it can flex the chassis some.
Do you let it cool for a bit before running each weld?
It doesn't affect the overall trailer, just a pain in the butt to shim out.
That's what I did...
tony.latham wrote:Did you bolt or weld the axle flange to the frame or did you use the Flexiride side mount hangers ?
What's a Flexride cost now? I'm curious.
Aguyfromohio wrote:We built two trailers with flexiride full axles
We bolted the axle to the frames on both. Used the standard top mount.
Drilled out an oversize hole in top tube wall to allow fastener head and socket to pass through
The fasteners clamp only the lower tube wall to the axle mount.
irhutch wrote:That was one of my thoughts since my tube is 3/16, thin kit would be plenty strong for that, thought of dropping bolts in like that then carefully tacking them in place should I need to ever change the axle, that or drill an access hole in my floor so I could get to the bolt.
