SoapCreek Adventure Trailer
Postby soapcreek » Mon Apr 29, 2019 9:16 pm
Edgewise thanks! There is definitely a feeling of accomplishment when you have your first overnight.
Off topic who hunts the mushrooms?
This was from this past weekend in SE Iowa.
soapcreek
Re: SoapCreek Adventure Trailer
Postby soapcreek » Sun Jun 09, 2019 3:10 pm
2900+ miles round trip SE Iowa to Idaho City, Idaho. The trailer followed great. Zero issues.
Hidden amongst the big rigs...
soapcreek
Postby soapcreek » Fri Aug 23, 2019 6:17 pm
Anyone else build a tiny boat to go with their drop?
Currently building a William Jackson Minimost. Image
soapcreek
Postby tony.latham » Fri Aug 23, 2019 8:21 pm
Cedar stripper...
:thumbsup: :thumbsup:
Postby soapcreek » Sun Feb 23, 2020 10:08 pm
Blowing the dust off my build thread...
The dual zone cooler worked great and had low power consumption for 8 days. Then it had a compressor failure. Spent the summer trying to get a replacement and eventually opted for a refund after the wrong replacement was sent. The unit could not be repaired as replacement parts were not available so it was a trash and replace item. It was nice not having to buy ice but pricey for a trash and replace from my POV. Eventually went back to ice and picked up a Kong cooler.
I added an ARB awning setup to one side of the trailer. Created some custom brackets for a quick attach setup. This is a picture of the bracket I mounted to the backside of the awning. A similar bracket with a slot was attached to the trailer.
soapcreek
Postby soapcreek » Sun Feb 23, 2020 10:21 pm
I didn’t get to use it as much as I would have liked last summer but we did make it out on Labor Day weekend.
The boat is coming along. I still have some finish work to do on it. I picked up a ‘58 Evinrude to power it. Believe it or not it was more difficult to get the boat licensed vs the trailer.
Made a welcome sign to put out while camping.
soapcreek
Postby soapcreek » Sun Feb 23, 2020 10:24 pm
That catches you up. Starting to think about getting on board water tank installed and kitchen finished out before the coming season.
soapcreek
Postby Az Pete » Sun Mar 01, 2020 2:56 pm
very nice design and execution. Too bad about the refrig/freezer. If someone makes a reliable one it will be on my list.
Az Pete
Postby soapcreek » Sun Jul 26, 2020 10:22 pm
Hello all, just wanted to drop by and post an update. A year ago I had a crack in my liner show up on the front radius. I chipped it away and repaired it. Well this spring another showed up and a few more on the rear of the roof. So this time I patched it and covered the front with some aluminum diamond plate. The rear of the roof will get a different treatment. So far the sides are holding up with the raptor liner. Pics of the new diamond plate and upgraded duct ports.
soapcreek
Postby tony.latham » Mon Jul 27, 2020 7:22 am
Is this a Raptor failure or is the plywood checking? (I know you epoxied it.)
It surely looks like you're enjoying it. :thumbsup: Certainly a fine build.
Postby soapcreek » Mon Jul 27, 2020 6:04 pm
Tony I would say it was due to the underlying plywood.
soapcreek
Postby tony.latham » Mon Jul 27, 2020 8:37 pm
What's the plywood? And what would you do differently?
:thinking:
Postby twisted lines » Tue Aug 04, 2020 8:54 am
soapcreek wrote:Off topic who hunts the mushrooms?
We have lots In the Oregon Cascade's But my walking is limited thank's to a texter :thumbdown:
soapcreek wrote:Anyone else build a tiny boat to go with their drop?
That looks so close to the little hydro's they race On the Rouge River, labor day weekend every year :thumbsup: except this year :thumbdown:
Not my size but I did pic up a new to me very low hour 07 honda motor with a boat under it this week :twisted:
At least I can hear the Tour Boats going by again now.
Racking up; And Rapin foam
twisted lines
Postby soapcreek » Tue Sep 15, 2020 8:43 pm
Am I the only one that allows time to get away from them? Teaser pic of the lower kitchen frame/drawers. Building as a removable unit so I can get at the water tank sitting below if needed. Everything built with scraps from the original build.
Pic from camping a couple weeks ago. Deployed the attachable awning room and doubled my square footage.
soapcreek
Postby soapcreek » Wed Sep 16, 2020 9:12 pm
Still need to put face plates on the drawers.
soapcreek
