by smeerkees » Sun Sep 08, 2019 3:21 pm
Now for some serious imaginary deviding skills i took some paint tape, some strings and a big square beam for the hight of the matrass.
Later i added a simple tarp to get a better picture of the inside space of the teardrop.
Ofcourse i knew in big lines how i want to make it, but with some very simple tools you can verify your plans in much more details.
And Yes i sat, and laid on the beam for some good and detailed space (ial) awareness (???) (How do you call that in english….)
The choise was a little bigger livingspace around your waistline when you are sitting up, or a somewhat deeper upper storing space.
I am chosing for the somewhat bigger livingspace. (So the upper storage space will be 4 inches less deep).
Remember i have storage space under the floor, at the back of the teardrop trailer, around the matrass where your upperbody lies, and some space on the seeling in the upper storing space.
I know you have never enough storage space, but at that high level from the ground you can store only light things.
The with of the matrass will be only betyween the wheelwells so i dont have a matrass with many strange angles.
So when you lay down the matrass under your upperbody is a little bit less wide, than the total teardrop trailer is but that's ok.
So that's it for now.
Next the last vertical rib at the back, paint the last things of the lower part of the teardrop, seal the outer edgesof the floor system, and mounting the floor system plus the underfloor storagespace.
Than the lower part of the trailer (from the ground till the floor) is basicly ready.
After that , doors, and hatch, and inner dividing walls.
Meanwhile i will lurk here on our site for some more detailed design ideas for the inside of the teardrop and the galley.
See you.
Greets, Smeerkees.
- Attachments
- IMG_2013 verkleind voor tnttt.JPG (53.05 KiB) Viewed 2914 times
- IMG_2014 verkleind voor tnttt.JPG (59.54 KiB) Viewed 2914 times
- IMG_2015 verkleind voor tnttt.JPG (49.94 KiB) Viewed 2914 times
smeerkees on Mon Sep 09, 2019 4:32 am, edited 2 times in total.
