RJ Howell wrote:If my Sleeper Cap was my primary camper, I'd be thinking of some sort of Gull Wing sides to be able to expand once located. Whether a counter area or sleeping platform, it would open up the small area you have available.
Now that you're fairly set on an idea.. Let me throw you a twist.. LOL
You're thinking through this well!
dbhosttexas wrote:
THere are some things I need to figure out that are holding up the design.
How can I make the bed / futon hinge where the base / bed doesn't dip below truck bed rail height when converting to a sofa?
How do I design the bed platform to support a max total combined weight of 600lbs?
Do I need to use Troppicool on the roof for even more thermal protection?
How do I insure the camper, truck and all, are level when we park to go to sleep? I don't want to have either, or both of us rolling toward the front of the truck by gravity when we sleep...
RJ Howell wrote:<How do I design the bed platform to support a max total combined weight of 600lbs?>
If sectional, 2 pieces, then your dealing with a max 300lb per. A 2x4 frame in wood wouldn't alone do that for the span, yet sistered with a angle may. Tat would only be on the support 'beams' and the balance could be easily done with 2x4's on the flat. Now, that's said without doing any math..
RJ Howell wrote:You're going to have to sketch this out.. Your futon is less than the bedrails.. Yet you want to be on the bedrails.. Hinging the sections seems like quite a PITA to setup.
2x2's, without the math, will not span the distance without bowing down. 2x4's would bow/flex on that distance. On wood structure as basic rule-of-thumb is one inch of height per foot. 6ft would mean a 2x6, and again doubled up. Tubular steel of aluminum may be your best bet.
Shoot us a sketch for what your thinking..
RJ Howell wrote:Now that's what I thought. The bed sections are larger than the futon. The futon/couch sits below the bedrails, so the sections will be short there of. Meaning the basic of the bed is permeant. The movable sections have to be placed between. Hinging those sections will be heavy and cumbersome to move around inside the camper. I'd think separate sections for ease there of.
You can't have sections larger than the bed width, couch, and think of moving upward to over the bedrails. Angle supports on the base upper section so the sections would fit in.
More sketches, more thought! Nice direction!
RJ Howell wrote:Guess I mis-understood the couch.. Sketches are awesome.. You have a floor layout yet?
Philip wrote:Here is a link with water tank sizes and prices.
https://www.tank-mart.com/rv-marine-tan ... er=gallons
I would think about two smaller tanks that would fit into the area in front of the wheel wells. Leave the area in the middle for items you would need more access to.
If your truck doesn't have a rear mounted fuel tank. You could under mount the water tank into that position and free up space inside the bed.
Users browsing this forum: Google [Bot] and 23 guests
