Questions on putting in windows
Re: Questions on putting in windows
Postby Carolina_coast99 » Fri Jul 19, 2019 8:40 am
I am planning to have the trailer manufacturer rough in the framing for my windows. Then I will cut out the aluminum skin after I get it home and instal myself.
Any advice/ lessons learned on what to request from the factory on this?
Carolina_coast99
Postby Iconfabul8 » Fri Jul 26, 2019 1:18 am
Carolina_coast99 wrote:I am planning to have the trailer manufacturer rough in the framing for my windows. Then I will cut out the aluminum skin after I get it home and instal myself.
Hopefully they will put the rounded corner pieces in. If not, install some and then use the framing as a guide and cut with a RotoZip! Best tool ever for cutting windows. (As long as you have a proper sized guide. Don't try to freehand a RotoZip)
Iconfabul8
Images: 14
DIY vs Factory install.
Postby brianjonesphoto » Wed Oct 23, 2019 2:16 pm
Forgive me if this answer is buried in this thread.
From the collective experience here I'm trying to figure out if I would be better off spec'ing windows installed in specific places at build time or installing the windows myself later? Price wise it's less than $100 a window to order them installed vs doing it myself. That seems like a reasonable labor cost assuming they are framed in. It would save me at least a half days time likley more.
Thanks
brianjonesphoto
Postby Rainier70 » Wed Oct 23, 2019 4:44 pm
If ordering I would have them put in.
Rainier70
Images: 244
Postby hankaye » Thu Oct 24, 2019 10:24 am
brianjonesphoto, Howdy;
I'll second what Cindy (Rainier70), said. Not only is it worth it but
if they screw it up they can fix it and you'll never know.
hank
hankaye
Postby Chickenthief » Sat Nov 16, 2019 12:42 am
I just ran across this video and thought that, even though it is van specific, it should be very helpful to anyone who's planning on doing their own work. This guy is a professional. It appears that he knows about a lot of the tips and tricks necessary to quickly complete a successful job.
https://youtu.be/oGO9MPwflb0
Chickenthief
Postby brianjonesphoto » Mon Nov 18, 2019 1:06 pm
Here's another window question. Has anyone every regretted putting in windows that are too BIG? I'm thinking 30x30 or 22x46 on the curb side and don't want to regret it.
Thanks.
brianjonesphoto
Postby FXDWG » Tue May 26, 2020 12:39 pm
hello again cargo trailer builders... i am looking for a supplier of rv windows that are 30 x 30 square. looking for the tinted ones with screens and trim rings. 1.5" walls.
i really like the ones that weroll.com uses on their trailers, but i have not heard back from emails or messages sent. and they dont answer their phone and the mailbox is full.
any ideas on who/where i could source these?
thanks and happy building.
FXDWG
Postby hankaye » Wed May 27, 2020 7:33 am
FXDWG, Howdy;
Try contacting these folks.
http://www.rvwindow.com/RV_Products_Lis ... goryID=238
hank
hankaye
Postby b.bodemer » Thu Nov 12, 2020 2:23 pm
I had a Stealth. They installed windows. Left dealer with specs as to where I wanted them( gave them height in inches off floor and distance from rear of trailer). Was worth it. You could always try to negotiate window price. That saved me some $$$$.
84677
Barb
b.bodemer
Images: 319
Postby flboy » Mon May 24, 2021 6:39 am
I recently installed windows in my new 6*12 build. Here is how I did it. I did weld in frames which would be how the factory would do it. There are other ways (and I have done it other ways), but this would be he strongest in my opinion.
I got a really good deal on two new RV windows and at the end of the day, I like building it myself.
However, if you are not sure of yourself, I would recommend you have the factory install as others have said.
https://youtu.be/R_TCqeIdL9Q
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Wrecit » Sat Feb 26, 2022 12:35 am
Love looking at all of your trailers. I do get a bit of a chuckle at your stealth designs. Not because I think you are doing something wrong but because I got my 4 ft long 2 ft tall RV junk yard windows going in my 12 ft trailer. Only way I can be less stealth is to mount a neon sign on the roof lol
You hide your conversion and call it stealth. I put mine out in the open and give it a beer.
viewtopic.php?f=50&t=74635
Wrecit
Postby Nitrohorse » Sun Aug 21, 2022 5:10 pm
If this question was answered in this thread, I missed it and I apologize. I am building a 6x12 v-nose and ordered two 20x24" vertical windows. My wall thickness is 1 1/2" and that was what I ordered in my new windows. I measure the gap between the window and trim ring and it comes out to 1 3/4". Is there a trim ring for 1 1/2" or do I shim the difference with 1/4" plywood. Any suggestions are welcomed and appreciated...thanks!
Nitrohorse
Postby Wrecit » Tue Aug 23, 2022 11:07 am
Tape off and run a heavy 1/8 inch bead of calk inside and out maybe? I am facing similar situation where my walls are 3/4 studs and the RV windows are 1 1/2 heavy inside to inside. Am thinking about doing an extra 1/2 inch of foam on inside or making a 1/2 in plywood dressing trim for around them.
Wrecit
Postby gadaibpkb » Mon Oct 31, 2022 2:59 pm
Thanks for sharing
gadaibpkb
