The build continues... at a slow pace! Winter vacation for us teachers is a good time for puttering in the workshop, as long as it’s after the holidays. I have a bit of time before school starts up again, so I chose to work on something small.
The big picture is I want to finish building the side cargo doors for my trailer, which I’ve mentioned at several points in this thread. That seems to be a long term goal, but I thought to myself that if I could finish the doors this winter, I’d be more likely to install them this spring when the weather warms up.
One thing holding me up was difficulty cutting precise 45° angles on my aluminum trim for the corners. Before we moved 2 years ago, I borrowed my neighbor’s mitre box and hack sawed trim pieces by hand. I really wasn’t looking forward to that job again, so I made a jig to hold the trim while I could cut it with a jig saw.
The jig is made out of some spare pieces of 2x4’s and some deck screws. It functions like a vise to hold the trim by squeezing it, and the tightness can be adjusted by the screws. I also use a clamp to hold down the trim as a secondary safety measure, because I don’t want pieces of it flying across the room or into me while sawing. Eye protection while cutting anything is a good idea, but is an absolute must when cutting metal.
I cut my first length of T-molding tonight after supper and it works! The cutting process is pretty loud though and I figured I’d hold off doing the rest until the neighbor’s young kids aren’t sleeping. It’s super easy to do, which makes me more motivated to finish this part of the build. There are outside-facing T moldings and inside-facing L-moldings on these doors. Lots of cutting to go, which is why I didn’t want to hand-cut them.
Once all the T-moldings & L-moldings are cut to length, the next steps are:
- Test fit and file down sharp edges.
- Drill screw holes in the molding and door edges.
- Counter sink screw holes.
- Test fit everything again just to be sure.
- Disassemble, and assemble again using Sikaflex to permanently seal the trim pieces to the doors and make the edges waterproof.
