I have an opportunity to get a Lion Energy lithium ion jumper pack at a discount. It sells for $145 but I can get it for $80.
Anyone have experience with these , good - bad brands, things to know, etc ???
Sent from my H1611 using Tapatalk
GPW wrote:Anybody tried them to power “camping things” ???
Aguyfromohio wrote:I was given one, a 7500 mAh unit just like this.
In my trailer the inverter charger can get itself stuck into a state where it won't accept shore power when the main battery is dead flat, it needs voltage across the main battery terminals for the transfer switch to move.
I needed a jump so I used that jump pack.
The little jump pack worked but only once. Got very hot and swelled up and broke the case.
I can't blame the jump pack, it died trying, sending huge amps into that much bigger battery. Hundreds of amps.
And it did succeed in it's suicide mission, the transfer switch moved and I had shore power back on line to charge up the main battery.
If I had thought things through (or read the instructions carefully, HA!) I would have known to only leave it connected for less than 5 seconds.
I'll probably buy another and use it correctly next time.
I'd probably get a better warranty with a harbor freight unit for the same price. Seems to have good reviews.
Users browsing this forum: Google [Bot] and 9 guests
