Hey everyone! So it's been a while. 5 months? Sheesh!! Okay, so I pretty much took most of the cold months off, but the longer days has convinced me to get some work done - finally! So here's some pictures of the ceiling ducting and lighting...
For those that don't remember, I have an air conditioner in the tongue box. The cool air is (will be) ducted up the front bulkhead and into the ceiling. The roof has a slight pitch to it and the false ceiling is flat. Between the two is the duct that will distribute the cool air from the air conditioner - hopefully most of the way towards the rear of the cabin and not just the front. The duct is approximately the same cross section as the air conditioner's output vent, but the length of the duct, the 90° turn and the turbulence from the spars will likely hinder the air's ability to make it all the way to the back.
If you look all the way to the front, you can see the gap in the bulkhead where the cool air enters the cabin from the tongue box. The spars that go side-to-side are part of the roof structure. The 2 strips that run front-to-back provide the gap for the air to fall out as well as a place to mount the led strip lights and the ceiling.
- DSC00470.JPG (114.26 KiB) Viewed 1530 times
Hopefully this shot gives you a better picture of how the air will (hopefully) travel down the length of the ceiling and fall out the gap along the edges of the drop ceiling. I think the spars might interfere with the air a little too much, so I might have to find some way of smoothing them out, but we'll see how it works first and go from there.
- DSC00479.JPG (122.73 KiB) Viewed 1530 times
Similar to the picture above, but this gives you a different perspective on how the air and light will come out of the ceiling. Speaking of... the ceiling will be into three sections and will be 3mm Baltic Birch laminated onto 1/8" hardboard, which you see in the picture. This will allow me to remove it with relative ease if necessary.
- DSC00480.JPG (120.82 KiB) Viewed 1530 times
More to follow...
