Running new wires inside completed build
Anything electric, AC or DC
Postby DoctahDeane » Sun May 17, 2020 9:42 am
Hi everyone - I found two great little reading lights that I plan to install. Although I have an overhead light, these are smaller and if one of us conks out early, the other could still read without disturbing. The inside of the trailer is all finished. Just talking two 14GA wires in each corner, alongside the pillows. I can use loom and stick that somehow to the corners. Just wondering if anyone has done something like this that looks better and keeps the wires out off the way/protected? Hope y'all hanging in there. Camping soon....
I keep stimulants handy in case I see a snake, which I also keep handy. W.C.Fields
DoctahDeane
Images: 38
Re: Running new wires inside completed build
Postby TimC » Sat May 23, 2020 8:01 pm
Depending on how you want it to look and if you want to create something out of wood... I can see cutting some thin strips from a complementary wood. Width of 3/4" might work for two conductor 14awg. Bevel the edges at 45 degrees. If thin enough it will flex and follow a curve up the corner of the wall. Soak in hot water if you need a little more flexibility.
14awg seem pretty heavy for a reading light. 12 volt? What is the amperage draw? Are they LED? My reading lights, 12v LEDs, use 20awg.
Tim
Tim
Niagara, WI
My First Teardrop Build Thread - viewtopic.php?f=50&t=63575
My Second Teardrop Build Thread - Started August '16 - viewtopic.php?f=50&t=66939
#3 Benroy Foamie build with/for my son - Started July '20 - viewtopic.php?f=50&t=72877
TimC
Images: 378
Postby DoctahDeane » Sun May 24, 2020 6:21 am
TimC wrote:Depending on how you want it to look and if you want to create something out of wood... I can see cutting some thin strips from a complementary wood. Width of 3/4" might work for two conductor 14awg. Bevel the edges at 45 degrees. If thin enough it will flex and follow a curve up the corner of the wall. Soak in hot water if you need a little more flexibility.
Tim
You're right, Tim. The wires are too big , I guess. I mean they work but I could go with something smaller like 16 or 20. I'll look into that and thanks for the suggestion on wood as well. I'll consider that, too.
DoctahDeane
Images: 38
Postby TimC » Sun May 24, 2020 7:49 am
I wasn't real clear with the thin strips idea. If you cut something 1/8" or less thickness it should be flexible. Might have sounded like I was saying 3/4" was thin. I suspect you understood. Just in case I confused someone else. Not sure if it would work, but, beveling a piece before you rip the thin strips might create several widths that give you a choice of final widths. There's youtube vids on simple jigs to cut consistent thin strips that you could use.
When I saw your beautiful woodie TD picture I thought, he's gonna want wood trim! Good job...
Tim
Niagara, WI
TimC
Images: 378
Postby DoctahDeane » Sun May 24, 2020 7:55 am
TimC wrote:I wasn't real clear with the thin strips idea. If you cut something 1/8" or less thickness it should be flexible. Might have sounded like I was saying 3/4" was thin. I suspect you understood. Just in case I confused someone else. Not sure if it would work, but, beveling a piece before you rip the thin strips might create several widths that give you a choice of final widths. There's youtube vids on simple jigs to cut consistent thin strips that you could use.
Thanks and I think I I can pry back some of the existing molding and run the wires behind, especially if I drop back to a thinner wire, which I've already ordered.
DoctahDeane
Images: 38
Return to Electrical Secrets
Users browsing this forum: Richard Grotto and 6 guests
