Thunder3 wrote:I'm running 15" wheels on my tear and has a matching spare on the tongue. It's really big and heavy and I would like to move the spare under the frame but it won't fit between the rails. I don't want to mount it on the side wall either or carry in the TV. Could I use a 13" or 14" as a spare in a pinch and not hurt anything? Same lug pattern of course. Thoughts?
bartek wrote:Yeah, that's my thinking as well - definitely looking for something good enough to just get to the next town, I just don't know how much I can push the size difference and still be able to drive for a short distance, even if at 30-40mph
exminnesotaboy wrote:If you have a 5x4.5 lug pattern, some full size fords in the late 90’s had a donut spare with an aluminum rim. I pulled one from a 99? Crown Victoria at a junk yard. It was never used, in great shape, matched my existing tire profile height and was only 10$. It was MUCH lighter than a steel rim and fit really well up under my teardrop frame. I believe these aluminum spares were some crown vics, mustangs and Lincoln town cars in the late 90’s. Might be worth a check of your local junkyard.
tony.latham wrote:exminnesotaboy wrote:If you have a 5x4.5 lug pattern, some full size fords in the late 90’s had a donut spare with an aluminum rim. I pulled one from a 99? Crown Victoria at a junk yard. It was never used, in great shape, matched my existing tire profile height and was only 10$. It was MUCH lighter than a steel rim and fit really well up under my teardrop frame. I believe these aluminum spares were some crown vics, mustangs and Lincoln town cars in the late 90’s. Might be worth a check of your local junkyard.
I take it the rim fit over your axle hub protrusion?
https://www.ebay.com/itm/273859201219?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=273859201219&targetid=1068323853830&device=c&mktype=pla&googleloc=9029516&poi=&campaignid=12594560362&mkgroupid=120171157815&rlsatarget=pla-1068323853830&abcId=9300522&merchantid=7850444&gclid=Cj0KCQjwjPaCBhDkARIsAISZN7RiCIzJxdvKHyA7t8dFQliueIkdOHp0Ts7o8x3ztkpVvBi2d5T-3mkaAor8EALw_wcB
Im sure you’re right. I posted that to show the hole in the rim.exminnesotaboy wrote:tony.latham wrote:exminnesotaboy wrote:If you have a 5x4.5 lug pattern, some full size fords in the late 90’s had a donut spare with an aluminum rim. I pulled one from a 99? Crown Victoria at a junk yard. It was never used, in great shape, matched my existing tire profile height and was only 10$. It was MUCH lighter than a steel rim and fit really well up under my teardrop frame. I believe these aluminum spares were some crown vics, mustangs and Lincoln town cars in the late 90’s. Might be worth a check of your local junkyard.
It did on mine(3500lb torsion axle with orig hubs) as I test fit it when I picked it up. Note: I am not sure that eBay posting you listed is for the lighter aluminum rim - it looks like it may be steel. Most eBay posting list them as aluminum if they are aluminum. I know I had to dig through a lot of junkyard late 90’s Ford/Lincoln trunks to find the one that didn’t attract a magnet.
