rmclarke wrote:Corroseal works great (or similar type product) if it's surface rust.....it chemically changes iron oxide to magnetite.
Used it on my old pop up tent frame; works super. (I didn't use their cleaner, just wire brushed it..then wash n dry.)
https://tinyurl.com/y6m39s75
{From Amazon ad: "Paint, prime and convert rust in one step - water based rust converter with latex metal primer."]
GTS225 wrote:While you're out, pick up some anti-sieze. Slather it on the hitch insert and start developing the habit of removing the insert when you aren't actually pulling.
Roger
DoctahDeane wrote:Besides cleaning up the receiver as discussed here, now I need to find a gorilla to separate the two ball mechanisms and then apply the 300 lbs of torque required. I do have a torque wrench but not a socket that big, nor do I weigh 900 pounds so I can't really lean in to it. Assuming a local car shop or parts store can help me with this.
GTS225 wrote:You're not the first guy to sacrifice an insert on the altar of education. Had a buddy many moons ago that had one seize up. He went so far as to chain it to a tree, and attempt a drive-to-the-end-of-a-short-chain removal technique. Didn't work. Partially ripped the hitch out from under the truck. Broke it at the weld on the left side of the receiver tube. Problem is that with the insert in, the moisture, (and salt, dirt, etc.), stays right in there and decays what paint is on it, then starts on the metal. All "downhill" from there.
Referring to taking the insert out when not actually in use; there's a number of states that actually have laws directing folks to do exactly that. Sorry, I don't know which states, but I seem to recall seeing it in Iowa DMV statutes. (No, it's not really enforced that I'm aware of.)
Whoops! Just did a search, and found that there's a FAQ that says there is no specific law requiring removal in Iowa. Color me em-bare-assed.
Roger
