featherliteCT1 wrote:Looks good and water tight.
I have Propex heater..
tony.latham wrote:I have Propex heater..
Did you get it fired up yet?
tony.latham wrote:You’re cranking.
Maybe you’ve thought of this but you might want to take the tank to your propane place.
They may want to install a new valve in it before they fill it. There’s something about the older tanks and the valves.
I still think you should be prosecuted for shagging that Propex for a hundred bucks!
It LOOKS like you know what you’re doing.lfhoward wrote:tony.latham wrote:You’re cranking.
Thanks!
That’s good advice about the propane place and the valves. I think I’ll have them swap over the new hardware that comes with it, instead of trying to do that myself. The tank still has the original 1987 VW regulator and fill valve.
See any other red flags in this photo that should be attended to when I have the tank serviced? Should it be repainted?
GO_C_DAVE wrote:Hey guys. Don’t mean to interrupt, but I would definitely take the tank to a propane dealer. They will inspect the tank, change out any out of date parts (and) certify the tank so you have a piece of mind. I always play it safe and let the experts do their job. Good luck and happy camping nice set up BTW
