Kit & Caboodle Foamie
Re: Kit & Caboodle Foamie
Postby GPW » Thu Feb 21, 2019 7:22 am
Really coming along Nicely !!! 8)
Postby Joe4Camping » Fri Sep 20, 2019 10:00 pm
Finished up the wiring in the tongue box. I've installed the shore power inlet on the right, which leads to a surge protector. This leads to the main PD4045 panel. The 35 aH battery (for interior lighting) is in the compartment below. A spare jug of water will live in it's own separate compartment in the lower right.
159481
Also finished the rear hatch cover. I skinned it with FRP and 1/4" plywood, so it is fairly light:
159482
Until I figure out which gas struts to use, I crafted this support bar, made of aluminum square tubing. The top is notched to lock into a cross brace:
159483
The bottom of the square tube is screwed into the kitchen counter, so it can swivel easily:
159484
And voila:
159485
Another easy project was this brown craft paper torn and glued using white glue, to the kitchen counter. Once it dries I'll stain it gray and seal it with several coats of varnish:
159486
Joe4Camping
Images: 88
Postby Joe4Camping » Sat Oct 05, 2019 7:07 am
Finished the cabinets in the sleeping area. I sawed quarter-inch wide strips, and stained each strip with a different stain, from all of the leftover stains I've accumulated over the years. Used 5 stains, Golden Oak, Gunstock, Jacobean, Ebony, Sedona (a very nice red tone), and Puritan Pine. Then glued them randomly on a quarter-inch plywood backing, and hung them up, with magnetic catches to keep them from flying open during travel. I'm happy with the results:
159615
Joe4Camping
Images: 88
Postby Joe4Camping » Sun Oct 06, 2019 7:51 pm
To protect the galley's piano hinge from rain, we simply siliconed and stapled garage door waether-stripping:
159628
Now, on to the kitchen cabinets. We are nearly done!
Joe4Camping
Images: 88
Postby Joe4Camping » Fri Oct 18, 2019 6:21 am
I've added a double fold-out tabletop in the galley. These are destined to hold my campstove and a cutting board.
The main foldout campstove tabletop is attached to the existing galley counter with a couple of hinges. I'm using a clasp to lock it in place in the open position:
159692
The second foldout is attached to the campstove foldout, and held aloft using a homemade telescoping leg. The leg is made from 1-inch square tube, with a half-inch channel sliding inside. Then a bolt with wingnut and split washer completes the setup.
159691
159690
Initial tests show this to be fairly sturdy. May put in a crossbrace just for added security.
159693
Folds up nicely too!
159694
Joe4Camping
Images: 88
Postby Joe4Camping » Sun Aug 30, 2020 1:25 pm
This past weekend, I created plywood fenders. I kerfed one end of a 8" x 24" piece of 1/2" plywood, and glued it up in an impromptu jig:
163059
Then gave it several coats of The Mix, attached a mud flap, and here it is attached:
163060
Joe4Camping
Images: 88
Postby Joe4Camping » Sun Aug 30, 2020 2:01 pm
Finally finished our little build (well, not so little, but a heck of a lot of fun).
Here's a bird's eye view, showing the skylight and fan:
163066
The front, showing the electrical box, housing the inverter/battery/shore access. The main cabin doors are cedar strips (meant to be used for closets, but seem to be holding up pretty well (slathered with linseed oil), glued to the door (which is just canvassed styrofoam). The splash guard (painted in an attempt at Native American design) is to protect the little window we put in front:
163062
The interior, with just a 4" piece of foam, and we'll add a heated mattress topper. The reading lamps are battery-powered.
163064
The rear of the interior cabin, showing the hand-made cabinets and drawers. The cabinet doors are just 2x4s cut into 1/4 inch strips, and each individually stained, then glued to a 1/4" plywood backing. Magnets ensure they stay shut during travel. AC unit is vented through the floor of the camper.
163065
And lastly, the kitchen area, with cabinets, a 'pop-in' sink, magnetic spice rack, collapsible tabletop extension, and builtin spoon & spatula holder on the right. The lower area will store our cooler, and propane stove.
163063
We've toured the neighborhood, showing our friends and neighbors the wee beastie, and the looks of delight make it all worthwhile.
Road Trip!!!!
:D
Joe4Camping
Images: 88
Postby Wolfgang92025 » Sun Aug 30, 2020 3:05 pm
Congratulation on getting the trailer to the camping stage. :thumbsup: :applause: 8) :beer:
Now it's time to hit the road.
Wolfgang
Wolfgang92025
Images: 651
Postby GPW » Mon Aug 31, 2020 5:29 am
8) :thumbsup: :applause:
Postby JazzVinyl » Mon Aug 31, 2020 7:01 am
Joe4Camping wrote:Finally finished our little build (well, not so little, but a heck of a lot of fun).
163066
Looks fantastic! Congrats and can't wait to hear of your adventured in it...
Well Done!
JazzVinyl
Images: 211
Postby Don L. » Wed Sep 02, 2020 4:55 pm
Your camper looks great! Thanks for sharing the pictures!
Link to my foamie camper build viewtopic.php?f=55&t=67321
instagram #don_leister_violin.rva
Don L.
Users browsing this forum: No registered users and 35 guests
