by lfhoward » Sat Sep 26, 2020 10:27 am
I found a brand of flame sensors that are universal, and they say to bend and cut them to match your original sensor. So I think it can be done. I ordered a couple of straight sensors that are the right length and have matching mounting hardware, and they should be here by the end of next week. I will give that a shot. I got two because they were inexpensive and because I thought I might break one.
Also, I am in communication with Propex UK and have asked them if they can ship me an OEM flame sensor for this heater. If they say yes, I’ll not need the sensors above, and I’ll use the one that they send. I’ll keep you all updated!
Assuming one way or another that I can get this heater running reliably, the next steps would be:
- Order exhaust and intake pipes, and heating ducts from VanCafe.
- Repaint the VW Westfalia tank and install the valves, then get it purged, filled, and tested.
- Install the propane tank under the trailer.
- Cut holes for exhaust, intake, and gas in my trailer floor, and install the Propex.
- Connect the gas line and run the wiring. Seal the gaps to make it weatherproof.
- Go camping!! Our next trip is in the middle of October, so I bet it would be nice to have heat by then, especially up in the mountains.
