tony.latham wrote:I don't know if there is anything short of concrete that tennis-ball-sized hail won't destroy. It would certainly total-out a car.
But keep in mind there are three types of foam board; extruded polystyrene (XPS -usually blue or pink), polyisocyanurate (poly - generally a yellow color), and expanded polystyrene (EPS -it’s white and sometimes called bead-board).
All three types have different characteristics of course.
I accidentally ran over a half sheet of 3/4" poly foam with my truck once that was laying on concrete. You could see the tread impression but it wasn't deep. I was surprised. Of course, the damage didn't heal itself. I think EPS would have been destroyed. I've got some blue XPS that needs to go to the dump. Maybe I'll give it a test roll-over and see how deep the damage is and see if it springs back after a few days.
we saw that all two days ago …
All from the Wind … Supposed to be ~105 mph , but some gusts were much higher …
GPW wrote:Tony , we did well, a oak tree fell on the house and punched a couple holes in my R-panel roof … Not bad considering the size of the tree .
Other than that just a bit of chainsawing and cleanup … lots of firewood for Winter ( wish I had a fireplace ? )
The trailer was remarkably untouched … ( dirtied with leaves ) Power is still out for a Lot of people … but we got a chance to test our little HF generator and solar panel kit … both worked exemplary !!! Like camping at home … sorta ‘ !!!
Here’s a couple pics … and you can see the holes right at the top of the roof … Not bad at all !!! On a ride around to find gas , we saw much WORSE damage … All from the Wind … Supposed to be ~105 mph , but some gusts were much higher … could have been a small twister. Everybody says a tornado sounds like a freight train , this sounded like heavy machinery running for hours ..
Mother Nature is PO’d at us and is giving us a proper “what for” …
little?GPW wrote: little messes out of everything , with our waste and fumes … Mother Nature is PO’d at us and is giving us a proper “what for” …
