twisted lines wrote:Really nice
Greg M wrote:You’ve just got to ask yourself “If I do the aluminum, will I feel like I cheaped out later?” If you don’t think so, then go for it.
saywhatthat wrote:Think of using a flat panel like you have used . When you glued them together and faired out the joints . Dose it stand out much? When ever I did joints like you have. I have ground out a tapper . But doing it your way would save a bit of time and mess.
Just finish a full rebuild of a kit trailer. So used the kit sidewalls with a lot of rot to make a Temple.
So if I did not have grind out a taper that be great . just thinking about looks . What are your feeling on the look.
