FREE: Dexter Torflex axle from T@B - Phoenix-area
Postby AzAv8r » Sat May 05, 2018 7:14 pm
(Edited 10/24/19 to change title - Free to good home!)
(** Edited to add price and an unfinished sentence.**)
I've replaced the standard axle on our T@B 320 with the lifted "Outback" axle, so I have the original axle available. The axle weighs over 100 lbs, so shipping would be challenging - thus, I'd prefer to sell it to someone who can come pick it up.
Specs:
rated 3000 lbs
10.5" electric brakes, 5x4.5" pattern
"drop" -> swing-arms are 22.5deg up from the horizontal. (for those curious, the "Outback" axle has 22.5 deg down)
48" between the frame-mount plates.
Dexter tag has the following:
PN 1447179.9
U29 FC 64/49.2 1MM 1B AKSM 10U UL FL 545E
A little beefy for a typical teardrop, but for a standy like the T@B this could be useful.
The mounting plates are tall (say 6"), so there are two 1/2" bolts on either side of the cross-member, and two above it. The T@B frame has a slot for the cross-member, and tapers vertically fore and aft of the axle-mounting position - a good design for a lightweight frame (the axle is Integral to frame strength).
I'll get a few pictures if someone is interested. Axle is from a 2016 T@B we bought used last year. We put 2000 miles on it; the people we bought it from put perhaps 1000 miles on it based on their described usage).
FREE!
Thx,
Jon
AzAv8r
Images: 6
Re: Dexter Torflex axle from T@B for Sale - Phoenix-area
Postby Bill n Robi » Sun May 06, 2018 6:53 am
Let me check the specs on it, I'd like to put brakes on my T@G, this might be an easier solution.
How much are you asking for it?
2015 T@G Max
2015 Toyota Tacoma TRD Sport 4 Door Short Bed
Bill n Robi
Postby AzAv8r » Sun May 06, 2018 8:11 am
$200 (+ shipping)
AzAv8r
Images: 6
Postby Bill n Robi » Sun May 06, 2018 6:43 pm
Getting info together, mine has a Dexter 2000 and I have the BOM for it from them, trying to locate yours for comparison.
We'd drive over to get it....
bill
2015 T@G Max
Bill n Robi
Postby AzAv8r » Sun May 06, 2018 8:16 pm
One thought = if your current axle has the tabs for the brake backing plate, it *might* be easier to just move the backing plates and hubs. Keep the spring rate the same. I don't remember whether Dexter axles always include the brake-plate tabs.
AzAv8r
Images: 6
Postby KTM_Guy » Sun May 06, 2018 8:46 pm
Some pictures would be nice. I'm local, in Mesa.
Todd
KTM_Guy
Images: 193
Postby AzAv8r » Wed May 09, 2018 8:38 am
Okay, pictures added to Gallery. Now let's see if I can make them show here:
Front view of the axle for sale, as-removed.
Right Top view of axle for sale:
Left hub of axle for sale. You can see the mounting plate shape/dimensions, and the 22.5 deg up-angle of the swing-arm.
Data Plate on axle for sale:
Replacement Axle installed (no picture of the original installed), This shows how it mounts to the frame, and the frame taper. Right Side:
Replacement Axle installed, inside left showing slot in frame for axle torque-tube/crossmember:
AzAv8r
Images: 6
Re: FREE: Dexter Torflex axle from T@B - Phoenix-area
Postby AzAv8r » Thu Oct 24, 2019 1:00 pm
Still sitting in the garage, so free for the taking.
I have some ideas on how to make this style of axle mount work with a typical box-beam welded frame.
Jon
AzAv8r
Images: 6
Postby Bill n Robi » Sun Oct 27, 2019 6:08 pm
Darn, I have to go back to San Diego next weekend to get the last of our stuff from the move to Big Pine. I could come get it the weekend of the 9th. I guess I could travel during the week, I forget I'm retired and there is no traffic in the eastern sierra's
2015 T@G Max
Bill n Robi
Postby AzAv8r » Sun Nov 03, 2019 9:03 pm
It's here, yours if you want it. Sent you a PM with contact info; we can work something out for pickup.
Jon
AzAv8r
Images: 6
Postby AzAv8r » Thu Jan 14, 2021 10:55 am
Still here, still free. Getting ready to post it on Craigslist or Offerup.
AzAv8r
Images: 6
Postby Douglas Knudson » Wed Jan 20, 2021 8:10 am
Do you still have the axle? Doug
2017 Jeep Sahara
2020 Homebuilt Foamie
Douglas Knudson
Images: 21
Return to For Sale/Wanted
