Construction adhesive and it fits pretty tight between the beams. The screws coming down from the floor also helped hold it while the glue dries.
Sent from my H1611 using Tapatalk
That is how I did my CTC except I used 2 inch Styrofoam. It does make a big difference even for cooling.Modstock wrote:Construction adhesive and it fits pretty tight between the beams. The screws coming down from the floor also helped hold it while the glue dries.
