My wheel came off!
Re: My wheel came off!
Postby Squigie » Mon Feb 01, 2021 1:08 pm
Lug nuts or bolts came loose - at least three of them.
That takes at least a little bit of time. Can be quick, but not instant. But, based on the "wear grease" pattern on the wheel, I'd say this took some mileage to reach finality.
Think carefully about what you were experiencing in the minute, 5 minutes, and 15 minutes before the moment of terror.
A loose wheel like that causes vibration, which gets worse and worse, until it all goes bad. Even though it was on the trailer, you should have still felt the vibration, and possibly even "hopping" of the trailer. The trailer should have also been visibly shaking before the last/second-to-last lug nut or bolt let go.
If you can remember what that felt like, you should be able to recognize it if it happens again, and stop before it gets to this point.
Having experienced several tire blowouts on several vehicles, it only took me about 3 seconds to recognize the problem when I felt the slightest vibration coming from this tire. The trailer seemed to be vibrating, too; but I wasn't 100% certain. At that time, the bubble was tiny. But by the time I was able to slowly make my way off of the highway, it was about a 3" bubble at the top of the off-ramp - and clearly visible in my mirror as I made the turn. Another 1/2 mile down the road, in a totally safe place to stop, jack the trailer, and change the tire, it looked like this. I was very happy to have recognized the symptom and gotten off of the highway immediately (-ish -- the next exit was about 2 miles away when I felt it).
Brand new tire, too. :x
Squigie
Postby swoody126 » Mon Feb 01, 2021 1:16 pm
Squigie wrote:...
what was the manufacture date on that tire ?
i've had "new" tires(over 5 years of age bitt never on the ground) do similar things just riding on the spare rack
sw
swoody126
Postby gudmund » Mon Feb 01, 2021 5:09 pm
maybe a bit late for this suggestion, but when you get this problem fixed - I suggest you invest in a 'clik'- ratcheting torque wench along with the 'proper' sized socket for the trailer lug nuts (along with the socket sized right for your tow vehicle also) I personally carry one in each vehicle I own (car has one under the drivers seat - PU tow vehicle has one right behind the drive seat) both are easily accessed at all times for use whenever I feel the need to check the torque, along with being the PUtruck one is seen every time I open the door it ends up being a 'good' reminder for me to check everything. As far as the $$$?.... have had good luck with the 'HF' cheap version (found it to be the same version being sold by W-M for twice the $$) have checked it again my good $$expensive$$ one from my shop toolbox numerus times and it is and has been very consistent in its accuracy comparison. And yes, one of these 'cheapy's' is probably not the most accurate out there, but they will give you a close enough "consistent" torque setting for each of the wheels lug-nuts when checking torque - which is what you want = 'even consistent tongue' on each lug-nut. Low-cost and if lost or stolen = not much $$lost$$....... Have been told by others, when I have been seen pulling it out to use, that I am being just a bit :? about this subject, but what's been funny about this subject ? - is when on some of the teardrop trips with others over the years, they end up being the same one's barrowing ""MY"" torque wench to check theirs's!! :thinking: ................
gudmund
Images: 39
Postby S. Heisley » Mon Feb 01, 2021 6:20 pm
swoody126 wrote:you're wecome
being an old retyred shop teacher who has towed trailers from izzard to gizzard and back SAFETY is always foremost on my mind
any time i can help someone/anyone avoid an/another incident i try
hopefully you'll be back on the road in good time and safely
sw
Good job explaining it all and thank you! :thumbsup:
Postby Squigie » Tue Feb 02, 2021 9:58 am
swoody126 wrote:what was the manufacture date on that tire ?
sw
It was less than 8 months old. I bought a pair.
When that one let go, I replaced both. Unfortunately, I was not in an area with much tire availability, and headed out for a 400+ mile trip and multiple days of camping; and refused to turn back. So, I have a mismatched set on the trailer now. One Carlysle, and a "better" Chinese brand. I need to get another Carlysle on it this year.
Squigie
Postby swoody126 » Wed Feb 03, 2021 8:50 am
Squigie, this is not meant to be argumentative butt...
¿ do you know how to read the age of a tire ?
it is now molded into each tire sold here in The States
on the sidewall there is a DOT number molded into the rubber and at the end of that number(usually in an oval stamping) there are 4 digits that tell the week and year the tire came out of the mold
the 1st 2 digits signify the week of the year and the last 2 signify the year
here are a couple pics explaining the stamping
i have found old stock being sold as "new" from time to time
not saying that's what you got
just offering information for future reference
BON CHANCE
sw
swoody126
Postby Squigie » Wed Feb 03, 2021 12:32 pm
swoody126 wrote:Squigie, this is not meant to be argumentative butt...
Yes.
As I said in the text that you quoted, it was less than eight months old.
Squigie
Postby swoody126 » Wed Feb 03, 2021 1:01 pm
2-thumbs up.jpg (24.95 KiB) Viewed 1893 times
sadly so many think that just because they just bought something it is new
i didn't know YOU UNDERSTOOD
no offence intended
sw
swoody126
Postby tony.latham » Mon Feb 08, 2021 7:00 pm
I'm wondering if anybody here can potentially diagnose the cause!
Dot:
What was the final diagnosis??? Don't hold us in suspense. :frightened:
Postby M C Toyer » Mon Feb 08, 2021 8:15 pm
tony.latham wrote:I think what may have happened was that the lug nuts were loose for a long time which caused the holes in the rim to wear bigger and bigger which created metal fatigue on the lugs and they failed.
I bought a used tire and had it installed on the way home from a job site with my 16 foot tandem axle work trailer. 7 miles to home backing in the drive the wheel fell off. Lug nuts loose but still on. The kid had only hand tightened them then got distracted. Enough slack and bounce in that 7 miles to expand every hole larger than the lug nut. Had a conversation the next day but my fault for not checking the work.
M C Toyer
Images: 11
Postby dotrosedotnet » Mon Feb 15, 2021 5:09 pm
Dot:
I think the lug nuts weren't tight enough! I had it repaired in DC. and I got my coupler replaced and my wiring redone in Gainesville. My experience in Gainesville was AMAZING. Can highly recommend the folks at Texas Trailer in Gainesville. Not so much the cats in DC. They broke one of my walls when replacing the wheels.
dotrosedotnet
Postby tony.latham » Mon Feb 15, 2021 5:25 pm
Ouch again!!! Repairable?
T
Postby dotrosedotnet » Mon Feb 15, 2021 5:41 pm
T
I got no other option! I'm holed up in the keys presently. Hoping to repair it while I'm here. I know that this is contentious (read: categorically inadvisable) but I left Philly with an unfinished camper. So I've been building it as I go. A very demanding and complicated endeavor.
Luckily my present situation is pretty amenable to the endeavor. I'm camping on someone's lawn and have all of my stuff under a tarp. Oy. Wish me luck!
dotrosedotnet
Postby tony.latham » Mon Feb 15, 2021 7:07 pm
Wish me luck!
:thumbsup: :thumbsup:
Users browsing this forum: Google [Bot] and 3 guests
