LiFePo4 Charger
Anything electric, AC or DC
LiFePo4 Charger
Postby bdosborn » Sat Feb 27, 2021 4:52 pm
I finally found a charger I like for LiFePo4 batteries. It's still not cheap but its programmable for individual cell voltages, does cell balancing and can discharge cells. I'm using a generic power supply to run it but you can charge using a lead acid battery, it converts the input voltage to whatever you need to for the cell you're charging/discharging. Max charge rate is 30A so it doesn't take a week to charge your cells when you're top balancing (like the 6A charger I was using did).
https://www.progressiverc.com/products/icharger-x6
It will charge all your RC batteries too. You could use it as DC-DC smart charger to charge your LiFePO4 from your tow vehicle alternator.
Images: 777
Re: LiFePo4 Charger
Postby John61CT » Sun Feb 28, 2021 8:55 am
Be sure to get a known good multimeter on it verifying voltage accuracies
ideally calibrated
Junsi's older pricier and bigger 4010-Duo has a better rep.
John61CT
Re: LiFePo4 Charger
Postby John61CT » Sun Feb 28, 2021 9:25 am
Best to buy from a hobby seller on your continent for better service, easier shipping back and forth
www.progressiverc.com are great, buddyrc and amain also
Ali eBay Banggood not so much, penny wise. . .
Check your firmware, v2.0.9 is latest stable I think
http://www.jun-si.com/UploadFiles/iChar ... 6_V209.bin
software
http://www.hillrc.com/soft/JunsiConsoleSetup.msi
manual http://www.jun-si.com/UploadFiles/X6%20 ... ual_en.pdf
The Junsi staffers that used to regularly participate in public forums are apparently gone
[email protected] was a good address to use
John61CT
Re: LiFePo4 Charger
Postby bdosborn » Sun Feb 28, 2021 9:57 am
John61CT wrote:Best to buy from a hobby seller on your continent for better service, easier shipping back and forth
http://www.progressiverc.com are great, buddyrc and amain also
Have you used any of these chargers? Also, you linked to the same company I did?
Images: 777
Re: LiFePo4 Charger
Postby tony.latham » Sun Feb 28, 2021 10:41 am
Exactly.
Re: LiFePo4 Charger
Postby bdosborn » Sun Feb 28, 2021 11:20 am
John61CT wrote:Check your firmware, v2.0.9 is latest stable I think
iCharger Updates - ProgressiveRC
The latest software version for the iCharger is version 3.14, which was released on December 24, 2010.
How old are your links? Sheesh, that would have bricked my charger.
Images: 777
Re: LiFePo4 Charger
Postby John61CT » Sun Feb 28, 2021 12:34 pm
different charger, X6 did not exist then
contact your vendor is best, and let us jnow
John61CT
Return to Electrical Secrets
