That is for sure a nice looking conversion. Glad you had a good outing. Hope to see you out camping in our state parks someday.
Richard
Frostproof Fl.
t-bear wrote:@Karebru
First, awesome job and true inspiration.
Thank you.
Couple quick questions:
1. Do you still remove the exhaust vent cover when using your AC? Have you tried running the AC with the exhaust vent in place since you baffled it?
The baffling made all the difference in the world. So far, we've spent one night in the camper using the AC. It was a muggy, low to mid 80s evening when we closed up and turned it on. It quickly brought it down to the low 70s. Once we were in for the night, I turned it down from high cool to low cool. I did not remove the vents.
2. Anything you'd change on your AC box/baffle system?
Time will tell. So far, so good. We aren't going to be inside during the day unless it's raining. So it's mainly for night time use. It might have to stay on high cool, but I think we'll be fine even on mid-summer nights.
3. Do you know your trailer's loaded weight?
I am curious to see how much I've added to the empty dry weight. I haven't taken it to a scale yet, but I really should. My mid-size truck does pretty well, but I'd have bought another full-size if I knew I'd be doing this with it. I'd rather be well below limits than "acceptably within"... I'm hoping to find a weight distribution hitch under the Christmas tree.
Thank you very much!
Thank you for asking!
Karebru wrote:t-bear wrote:@Karebru
Thank you.
Karebru wrote:Good morning,
I've never used a WDH. So setting it up will be a fun learning experience.
Karebru wrote:I also made a liner/drip pan out of cellular PVC board for my AC cabinet. There's a barb fitting at the bottom for a drain hose to attach to.
