Flame by the end of the generator on 425 stove.
Re: Flame by the end of the generator on 425 stove.
Postby working on it » Sun Jun 30, 2019 12:38 pm
* My dual-fuel two burner has started to do the same. I think that there's soot in the burner itself, or something causing back-pressure that forces the flame to back up. I've never cleaned it, though, but before next camp-out, I''l use some brake or carburetor cleaner spray on mine, and see if it clears up.
173193172890148599
working on it
Images: 457
Postby dbhosttexas » Wed Jun 23, 2021 4:10 pm
working on it wrote:* My dual-fuel two burner has started to do the same. I think that there's soot in the burner itself, or something causing back-pressure that forces the flame to back up. I've never cleaned it, though, but before next camp-out, I''l use some brake or carburetor cleaner spray on mine, and see if it clears up.
I just stumbled on this thread. What was your result with this?
My 424 did this but I just ran the valve all the way open, closed, and the light / run lever in out several times. I replaced tthe dried out packing and ran a tank of regular unleaded gas with carb and injector cleaner through it. No more backflame...
dbhosttexas
Images: 29
