#5
Re: #5
Postby ghcoe » Thu Aug 19, 2021 4:17 pm
aggie79 wrote:Thank you for your explanation! I’m trying to build up my foamie knowledge base for a potential project.
George.
ghcoe
Re: #5
Postby ghcoe » Mon Aug 30, 2021 12:15 pm
Some more updates to #5
Tested fitted the back wall after cutting out.
Test fit
20210814_085923 s.jpg (356.41 KiB) Viewed 1587 times
After the test fit it was time to cut out the door. I had already canvased the inside wall so I marked my door pattern out.
Preparing to cut out the door
20210821_164728_HDR s.jpg (401.83 KiB) Viewed 1587 times
Then I cut out a small channel for the hot wire to follow.
Hot wire channel
20210821_164734 s.jpg (339.83 KiB) Viewed 1587 times
George.
ghcoe
Re: #5
Postby ghcoe » Mon Aug 30, 2021 12:24 pm
Then it was time to install the rear wall.
Installing the rear wall
20210822_094722 s.jpg (350.91 KiB) Viewed 1587 times
Aligned and clamped for the glue to dry.
Everything is aligned
20210822_102709 s.jpg (375.99 KiB) Viewed 1587 times
And a shot after the clamps are removed.
Installed
20210823_122607 s.jpg (354.78 KiB) Viewed 1587 times
George.
ghcoe
Re: #5
Postby ghcoe » Mon Aug 30, 2021 12:33 pm
I have been trying to find a hitch that was going to work well for this project. In most cases the hitches I have seen on other builds were home grown. There are a few common hitches that attach to the rear axle and they are easy to find. I needed something that attached to the seat post or a bracket that came out behind the rear tire. There are a few of those out there, but they usually proprietary and cost quite a bit. I was watching a person in Europe that showed this hitch briefly in his video and so here it is. They are a bit hard to find to get to the states, but it is a nice sturdy hitch and should work fine for this build.
Hitch
20210826_175029 s.jpg (348.85 KiB) Viewed 1584 times
George.
ghcoe
Re: #5
Postby CRZ42 » Mon Aug 30, 2021 2:49 pm
That is a real slick hitch. Far nicer looking than a lot of the ones that mount to the rear triangle.
CRZ42
Re: #5
Postby Terra6 » Tue Sep 21, 2021 3:55 pm
Currently there is a guy building a bike trailer like yours in the foamie section on FB you might want to check out. It's very similar to what you're doing.
On the road to Shambala...
Terra6
Re: #5
Postby ghcoe » Tue Sep 21, 2021 6:13 pm
Terra6 wrote:Currently there is a guy building a bike trailer like yours in the foamie section on FB you might want to check out. It's very similar to what you're doing.
I have caught bits and pieces of the build. I tend to stay out of FB especially the foamie thread, what a disaster....
George.
ghcoe
Re: #5
Postby DrewsBrews » Wed Sep 22, 2021 9:26 am
Sounds like you are looking for something more slick, but like you are finding it seems like most commercially manufactured trailers use proprietary couplings. This piqued my interest so I poked around a bit myself.
Dont know if you saw this one. Seems fairly simple to assemble without needing to weld.
https://www.instructables.com/Bike-Trailer-Hitch-2/
DrewsBrews
Re: #5
Postby aggie79 » Fri Dec 24, 2021 6:51 pm
Hi George,
Haven't heard from you in awhile. Did you finish #5?
Take care,
Re: #5
Postby ghcoe » Fri Dec 24, 2021 7:02 pm
No. Caught Covid in early September and blew 5 weeks in bed. By time I recovered and got caught up with everything else I had to do there was no time to work on #5. Too cold now. Hope to hit it hard in the spring now. Thanks for thinking of me. George.
George.
ghcoe
Re: #5
Postby GPW » Sat Dec 25, 2021 5:39 am
Thank Goodness you're recovered !!!! :thumbsup:
Re: #5
Postby ghcoe » Sat Dec 25, 2021 2:29 pm
GPW wrote:Thank Goodness you're recovered !!!! :thumbsup:
Thanks!
We were more worried if my wife got it since she is type 1 diabetic. She faired pretty well considering. She was back at work after the 14 day quarantine. Put me down a bit longer than expected, but pulled through fine.
George.
ghcoe
Re: #5
Postby aggie79 » Mon Dec 27, 2021 7:03 pm
Glad to hear y’all are okay!
Sent from my iPhone using Tapatalk Pro
Re: #5
Postby sgraham » Sun Sep 04, 2022 12:31 am
Hope you're well. I've become recently-obsessed with trying a build like this, and really like the design you came up with. Thanks for posting the pictures that you did.
Do you happen to recall the name of that small hitch you found?
Were you able to finish this build? Any tips/hints if I was aiming to copy you? :)
sgraham
Re: #5
Postby sgraham » Sun Sep 04, 2022 1:06 am
sgraham wrote:Do you happen to recall the name of that small hitch you found?
Ah, perhaps "Ventura Zinc Coated Bicycle Trailer Hitch for seat tube or seatpost clamp" (didn't want to post a link that looks like spam since I only just registered here!)
sgraham
