First new to the board so be gentle lol. Have a 1995 6x12 Hallmark that I got the bright idea to convert to a RV (someone shoot me) I am a union carpenter with the skills to think way to big so here's my question.
I demo'ed the rear of the trailer and have welded the framework to have an 18 tall by 30 wide cargo door at the bottom and a 37x 57 door on the top. The larger door is for a "pop out to slide a full mattress out to give more interior space.
My question is what piano hinge would you recommend. I would like to use an aluminum gear hinge but am really questioning how it would hold up in a horizontal application.
Total static door/hatch weight should be 250 to 300 lbs (steel welded frame double 3/4 plywood and mattress) am thinking need to put fail weight at 750 to 1000 lbs to account for wife and I sleeping and "not sleeping" on it.
The door will be held in place when open by 1/8 inch flat stock bolted to frame.
Am I over engineering and what piano hinge should I use
