saywhatthat wrote:If you use 3/8 hardboard and plasticine clay you would have a smooth outside surface do a shell then add foam then glass over.
saywhatthat wrote:look at the trail top build . That a shell with right foam glue in. then glass a few layers over foam on inside
saywhatthat wrote:Do you have a link?
Frank R wrote:This is very promising and looks like it could scaled up:
https://thetinkersworkshop.blogspot.com/2015/03/teardrop-trailer-holy-grail-project.html
Frank R wrote:Here is a post on how he worked with a foam strong back and forms, and then covered them in strips. You can click the Newer Posts at the bottom of the page to see how this project progressed.
https://thetinkersworkshop.blogspot.com/2013/09/terratrike-velomobile-glued-trimmed-and.html
This guy is amazing. Look at all he accomplished.
saywhatthat wrote:LOL
You need to do a hell of a lot more research they're made from polyester and chopper guns.
saywhatthat wrote:If just pulling a few [/quote ]
at one time that imply tooling
Osb for the floor seems to be a sketchy choice. Otherwise entertaining.Frank R wrote:This is an excellent video to watch on how Scamps are built:
https://www.youtube.com/watch?v=9fnU-D2lWG0
