billyq wrote:Thanks for the calculator and discussion. My original struts were way too short, and I spent a lot of time messing around trying to figure out how to make them work, before your calculator helped me get the correct ones, installed in the right place.
Vaughn771 wrote:Hey there! Question about the weight rating for the struts: When I get the weight at 50% hatch length, do I get EACH strut to lift about that weight? Or am I dividing that weight by two, and getting each strut to support HALF the weight? Sorry if this is obvious...
danlott wrote:Just a reminder. The spreadsheet calculator is designed to be utilized when your gas struts are installed in a more vertical position similar to how they are illustrated in the picture. A more horizontal position will require more force and the calculator is not designed for that. Also, the more force required will place increased forces on your hatch, galley, and hinge area, which can lead to failure.
Dan
...since the struts I am finding only give the extended and compressed lengths and I cannot find anywhere that tells me how to compute the stroke length.
DesertApprentice wrote:The standard drawing shows the structs lean in a forward position when fully extended.
Since my hatch is relatively vertical, following the formula, my struts would lean backward when fully open, see the red line in the illustration.
Do all the calculations still apply?
Thanks a lot!
Users browsing this forum: Bing [Bot] and 6 guests
