Gerdo wrote:Who has an LCD TV in their Tear? I want to use a a 17" on 12 volt DC. Can this be done?
Chris C wrote:Don't have a screen yet...............heck, don't even have a teardrop to put it in but when the time comes, this is what we want:
http://www.campingworld.com/browse/skus ... 5&src=CROS
It should look like a full screen movie theater since we'll be so close!!!
GeorgeTelford wrote:Simplist way to run a LCD on 12v is via a small invertor.
A charged battery should read 12.8 ish this is only 6 % over and should be fine, but do be careful not to run it via the battery when the battery is charging at this point the voltage will be a minimum of 13.8 Volts this is 15% OVER a good charger could be as high as 15Volts and this is 25% over, I certainly would not want to risk the TV at these voltages.
Many TV's have a 12v Power supply, but this is real 12, do not mix this up with your tears battery if your tears battery read 12v on a meter it would be flat.
