If it were me, I would use Raka thin set epoxy and float the aluminum.Onajourney wrote:John- Thanks. Like so many things here, there are numerous ways to do things. My plan is to epoxy ~12" around all corners (my is a squaredrop) and use a minimal amount of contact cement to assist this one man crew to skin the aluminum. SO you are saying do not epoxy anything? I am ok with that but Tony beat into my head to epoxy everything. If you had to do it again, what would you do?
I am going to epoxy all edges and corners then Paint the whole thing with Henry sealant.
tony.latham wrote:I am going to epoxy all edges and corners then Paint the whole thing with Henry sealant.
Why not seal the entire cabin with epoxy? That's what I have always done on cabins before floating aluminum.
The BB is not.
tony.latham wrote:The BB is not.
You can throw a chunk of Baltic birch in a bucket of water for a week, put it out, and after it's dry, nothing has changed.
