M&M's Droppie
M&M's Droppie
Postby TallGuy7 » Thu Sep 22, 2022 12:48 pm
Time to fit the wheels on the trailer. Spacers finally arrived after months of waiting. The rims where rusty so I put my angle grinder to work...
Ready for primer and paint.
Watching paint dry.
Verzonden vanaf mijn iPhone met Tapatalk
TallGuy7
Images: 26
Re: M&M's Droppie
Postby shannonswyatt » Fri Sep 23, 2022 2:32 pm
Looks like you are gambling on that paint job.
I'll be here all week folks!
shannonswyatt
Re: M&M's Droppie
Postby nsfr1206 » Fri Sep 23, 2022 10:36 pm
Interesting use for playing cards. That’s a new one for me!
nsfr1206
Re: M&M's Droppie
Postby TallGuy7 » Sun Sep 25, 2022 6:30 am
Easy way to keep paint of the tires…
Perfect result with minimal effort.
TallGuy7
Images: 26
Re: M&M's Droppie
Postby TallGuy7 » Sun Oct 02, 2022 12:44 pm
After a lot of sanding, more sanding and even more sanding it was time to put some colour on Droppie.
TallGuy7
Images: 26
Re: M&M's Droppie
Postby TallGuy7 » Sun Oct 09, 2022 3:17 pm
Been busy with the build. The weather continues to be diy-friendly.
Second layer of 2k paint on the galley hatch.
Also the TD got a second layer of paint.
Preparation for glueing the aluminum diamond plate on the front.
Waiting for the glue to set.
Installed the hurricane hinge on TD and the hatch.
Edge trim and lights mounted.
Tomorrow I will flip the hatch and fix the spot lights on the inside and glue in the rubber d-seal. Also the moment to install the improvised hatch lock.
TallGuy7
Images: 26
Re: M&M's Droppie
Postby TallGuy7 » Tue Oct 11, 2022 2:23 am
Since Vintage Technologies does not ship to The Netherlands I could not order their hatch latch.
After a lot of browsing I decided to modify an espagnolet latch. I took it all apart and combined it with a Lockable T-grip that I modified to fit the latch.
This is the result.
And now it’s time to fit the hatch to the TD. Hopefully someone can help me this evening to slide it into position.
TallGuy7
Images: 26
Re: M&M's Droppie
Postby tony.latham » Tue Oct 11, 2022 10:41 am
I have always attached the (full) hurricane hinge to the hatch, laid a strip of butyl tape along the edge of the roof, and set the hatch in place. Once it's perfect, I screw down the upper portion of the hinge.
Knowing me, I'd monkey up the hinge by trying to slide it in. :frightened:
:thinking:
Re: M&M's Droppie
Postby TallGuy7 » Tue Oct 11, 2022 11:38 am
Monkey it will be….
Help is coming….
TallGuy7
Images: 26
Re: M&M's Droppie
Postby TallGuy7 » Tue Oct 11, 2022 12:41 pm
Result!!!
TallGuy7
Images: 26
Re: M&M's Droppie
Postby chopperwalker » Tue Oct 11, 2022 2:23 pm
It looks great!
chopperwalker
Re: M&M's Droppie
Postby TallGuy7 » Sun Oct 16, 2022 1:20 pm
This weekend I planned to get TD closed.
Except for the left side aluminum profile I succeeded.
The xxl stargazer window was installed. I used 10mm polycarbonate that I cut to size. On the inside I created two shallow gutters that lay on the 50mm and 3mm thick butyl tape. The butyl filled these two gutters so I hope it will be watertight. Future will tell.
Doors for the Lafuma garage are ready. Other doors got a last coat of paint.
Fabricated the doors.
Mounted locks and net on the inside of the doors.
Fitting the stargazer window.
Perfect fit.
The inside of the cabin got its final coat of paint. Also installed the windows and doors.
Next week the gas struts will be fitted. That task worries me a bit. But I will manage I hope.
TallGuy7
Images: 26
Re: M&M's Droppie
Postby TallGuy7 » Mon Oct 17, 2022 4:54 pm
This evening completed some small tasks…
Lights and cover for the Maxxfan installed.
Reading lights and usb charger installed.
Exterior light fitted. And I had to remove the door on the right hand side because I didn’t like the way it closed, needed too much force.
On the way to road legal…
Doodling with the wiring.
Also figured out the way to mount the struts with the help of noseoil.
TallGuy7
Images: 26
Re: M&M's Droppie
Postby S. Heisley » Mon Oct 17, 2022 7:22 pm
:D It's looking great! :SG
Re: M&M's Droppie
Postby TallGuy7 » Tue Oct 18, 2022 7:09 am
Good thing I designed everything in SketchUp and build accordingly. As a result fitting the struts was a very easy task (with some help from Tim (noseoil) and the excel gas strut calculator.
Biggest challenge was finding a position that resulted in an acceptable height and keeping it closed when down. In the end I just did it.
Everything went smoothly, but when pushing the hatch down the screws broke out…. So off to the diy store.
This is the result:
If I knew how to include a movie of the hatch opening I would have added it… it opens very smoothly.
I call this succes!
TallGuy7
Images: 26
