And I can run 12 V off battery to power vent/fan and lights?
If I'm boondocking, I need an inverter to run CPAP.
tony.latham wrote:You'll lose a considerable amount of power. What makes sense is to get a DC cord for your CPAP. That's what I run my Phillips CPAP with.
I also don't use the heated tube when boondocking. It eats up too much power.
It depends on the machine.
tony.latham wrote:It depends on the machine.
I was referring to the 20% power loss from inverters.
Setting up for 12vdc would be bad if his machine is 24vdc.
Fwiw,I was intending to make sure the OP looked at his machine's input voltage requirements before diving into things too far. Setting up for 12vdc would be bad if his machine is 24vdc.
Users browsing this forum: Google [Bot] and 0 guests
