Willard wrote:If the trailer is 5' wide,outside to outside,then how long should the axle be? So far my options are 69" and 73",one seems too short and the other too long???Help
Leon wrote:Actually, the term "Backspace" when you are talking to a tire guy or axle supplier is measured from the rim of the wheel not the bulge of the tire.
angib wrote:Leon wrote:Actually, the term "Backspace" when you are talking to a tire guy or axle supplier is measured from the rim of the wheel not the bulge of the tire.
100% right there, Leon. I was trying to keep things simple(r).
I've modified the diagrams above to use the term 'tire backspace'.
Andrew
madjack wrote:John, that sounds correct to me...we just figured on one for KA with a 57.5 frame and an overhang coming out to a body size of 60" and it came in atta 71" minimum...your frame is 1.5 wider and they gave ya another 2"s.......
Users browsing this forum: No registered users and 27 guests
