Pmf overlapping joints
Finishes, paints and coatings
Postby Simple_Abound » Sat Feb 10, 2024 10:41 pm
It's been over 3 years and over 6,000 hard miles since my first homemade camper hit the road. It rained over 2 inches that first night and was pelted with acorns. I covered it with pmf, I had no idea what I was doing, some of it looks hideous. I've had zero issues with it. I have decided to cover my second build with pmf. I'm looking for the best way to make the roofline joint look the best I can. I'm leaning towards overlapping the sides and roof 2 inches. Pictures of first build for reference.
Thank you
173073173075173074
Simple_Abound
Images: 82
Re: Pmf overlapping joints
Postby TimC » Sat Feb 10, 2024 11:44 pm
Another testimony to the reliability of pmf. I've had similar experience with my seven year old first build.
Tim
Niagara, WI
TimC
Images: 734
Postby Simple_Abound » Wed Feb 14, 2024 7:37 pm
TimC wrote:Another testimony to the reliability of pmf. I've had similar experience with my seven year old first build.
I would have to agree, my fenders were so chipped from gravel roads I put Herculiner on them. The pmf not one imperfection, it's been in 100 weather to 20 below weather.
Simple_Abound
Images: 82
Postby CanuckShooter » Sat Apr 13, 2024 10:15 am
It will look better if you canvas the sides first with it overlapped top and bottom, then when you lay the roof canvas go right to the edge of the roof. So you end up with about 2" of double thickness. IMHO Mine has gone 3 years out in the weather all year round and no issues to date.
CanuckShooter
Images: 113
Postby Pmullen503 » Sat Apr 13, 2024 4:26 pm
When I did mine a I made a guide (just a block of wood with a piece of 1/4" ply extending 2" over the edge)and ran it along the roof, using the plywood as a guide for a (sharp)utility knife to trim the excess roof canvas. I was lifting the cutoff canvas (glue was still wet) as I went to make sure I wasn't cutting into the wall canvas. Slow going but it worked.
Pmullen503
Images: 67
Postby TimC » Sat Apr 13, 2024 5:36 pm
Same as Pat though I put a thin piece of plywood scrap below the roof canvas to cut against. Worked well. I used my wife's little fabric cutting wheel thing. I don't know what they are called but they cut very well and don't pull the canvas in the direction it is being cut.
After cutting I reapplied glue under the overlap to make sure it had plenty. And came back after a while several times over a couple hours to press it down in case bubbles were present.
Tim
Niagara, WI
TimC
Images: 734
Postby Simple_Abound » Wed Apr 24, 2024 5:57 pm
I was debating where to make the seams. The seam on the roof and underneath will look cleaner.
Simple_Abound
Images: 82
Postby philpom » Mon May 06, 2024 7:11 pm
A few others noted place the seam on top - out of site and a much better look. I did similar to the driver and passenger sides so no visible seams on those either.
My PMF has held up very for for the 3 or so years it's been outside.
A shadow is making this seam show more than it does in full sun, it's down tight. It also needs a bath :)
philpom
Images: 101
Postby Eskapet111 » Tue May 07, 2024 10:33 am
Hey everyone ,
I made a post in another thread asking about patching a hole in my pmf camper and I was suggested by Rob to ask in here about it .
If anyone could please have a look at my thread post and give any advice that would be very much appreciated.
Thanks !!
Link to my thread post
viewtopic.php?f=55&t=76361&p=1305900#p1305900
Eskapet111
Postby TimC » Tue May 07, 2024 10:48 am
philpom wrote:... I did similar to the driver and passenger sides so no visible seams on those either...
And that looks great!
Tim
Niagara, WI
TimC
Images: 734
Return to Skinning secrets
